Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
30 Jul 2018, 01:04
What about drag though. In some aeroplane books they say stall increase drag as well. why doesn't that apply to F1 rear wings? We always hear of stalling to reduce drag in F1.
Because pressure difference on an F1 car is significantly larger than on an aeroplane wings due to much more aggressive airfoils, cambers, angles of attack etc. So, with stall, you decrease pressure difference on wing surfaces on an F1 car (and very likely most single seater prototypes), but it increases on an aeroplane. This drag increase with stall is even more pronounced on gliders, as their wing drag (compared to wing surface) is ridiculously low. :)
Vanja #66 wrote:
30 Jul 2018, 21:52
30 Jul 2018, 01:04
I see thanks. I have been pondering.... Suppose in F1 a "stall" is a loose word for "way less lift" instead of boudary layer separation stall... Is there evidence of boundary layer sepration and "unpredictable behaviour" in deliberately "stalled" rear wings?
roon
roon
412
31 Jul 2018, 03:43
zibby43
zibby43
New front wing being tested on the W09.
https://twitter.com/albertfabrega/statu ... 28864?s=21
mantikos
mantikos
35
zibby43 wrote:
31 Jul 2018, 11:13
As predicted, there they go improving the front end...after they've improved the rear
djos
130
djos wrote:
28 Jul 2018, 14:21
Some of you Mercedes fans need to spend some time in old RedBull car topics to comprehend how the high rake concept works.
I'll give you a tip tho, without sealing the sides of the floor, it doesn't! The whole point is to gain a larger diffuser volume than the rules technically allow, which increases down force.
So apparently it's a crime (penalty being a down-vote) to point Mercedes fans (note I never used the derogatory "fan-boi's" term) to topics about a competing car which contain multiple years worth of analysis as to how the high rake is achieved and it's benefits! #-o
"In downforce we trust"
240
wesley123 wrote:
27 Jul 2018, 20:43
mantikos wrote:
27 Jul 2018, 20:22
wesley123 wrote:
27 Jul 2018, 18:48
The rake is about traction, not generating more downforce. The rake allows for a softer rear suspension, which will improve traction. Something that is really useful with these V6s.
People like to differentiate those three tracks based on downforce, but in reality, they differentiate largely on traction. And that is the thing that Mercedes have struggled with, and that is also why they perform so badly on these tracks.
If it actually was aero that was the differentiating factor, Mercedes would have sucked pretty badly in Barcelona, which they did not.
Sorry, you're wrong, it decidedly has an aero impact as well
It's aero, however, isn't the goal.
It is and has always been driven by aero. Ever since the first redbull that had pronounced rake. If you look back far enough on this forum. I think ive done some CFD experiments with varying rake, there is increased downforce from the floor.
djos
130
ringo wrote:
01 Aug 2018, 02:02
That brings back memories ... iirc, the evidence was pretty conclusive. 8)
zibby43
zibby43
Imageimage1(5) by Andrew R., on Flickr
Another photo of the new front wing with the additional "r" cascade.
mantikos wrote:
31 Jul 2018, 17:02
zibby43 wrote:
31 Jul 2018, 11:13
Those top devices are intended to help the outwash and thus better control of the tyre wake. That has more of an effect at the rear of the car, not the front.
Possible double pillar RW mounting
via PG Tech
zibby43
zibby43
MtthsMlw wrote:
01 Aug 2018, 14:18
https://4.bp.blogspot.com/-NaFHV7JiYmo/ ... 1600/1.jpg
via PG Tech
Very interesting.
Just_a_fan wrote:
01 Aug 2018, 09:26
Slightly conspiracy like here but...if you've just done a load of research on with the FIA showing outwash hinders overtaking. And you have the fastest car in qualifying but maybe not any more in the race...if you find a way to add a little more outwash without hurting anything else up front.... :lol:
LM10
LM10
127
MtthsMlw wrote:
01 Aug 2018, 14:18
via PG Tech
This would make it possible for them to do the same wastegate thing as Ferrari has tested recently.
Sempre Forza Ferrari
