Running with -0.3° rake atm. Tried -0.6° for a while but i couldnt make the diffuser work with that angle. Rake certainly helps to a point for the frontal area but even with that im no where near to the bar that i set preseason.
Lurking again. Have you tried dropping your front wing/diffuser angle. Getting closer to the ground with rake should improve front downforce - such that dropping the angle reduces upwash and stops robbing flow from cooling and rear diffuser. Also look at the angle air is entering your cooling ducts. You want to align them to the flow to minimize separation in the duct.
The difference between -0.3° and -0.6° is huge. I would try -0.4° at this point, but it is a pure guess based on my car layout.
Right now, I am doing exaclty what you wrotejjn9128 wrote: ↑Mon Aug 06, 2018 3:25 pmLurking again. Have you tried dropping your front wing/diffuser angle. Getting closer to the ground with rake should improve front downforce - such that dropping the angle reduces upwash and stops robbing flow from cooling and rear diffuser. Also look at the angle air is entering your cooling ducts. You want to align them to the flow to minimize separation in the duct.
I will try that.jjn9128 wrote: ↑Mon Aug 06, 2018 3:25 pmLurking again. Have you tried dropping your front wing/diffuser angle. Getting closer to the ground with rake should improve front downforce - such that dropping the angle reduces upwash and stops robbing flow from cooling and rear diffuser. Also look at the angle air is entering your cooling ducts. You want to align them to the flow to minimize separation in the duct.
I always go back to this when creating my cooling intakes.
Pretty cool car! The are some interesting details (engine intake position, for example). And those rear wheel fenders remind me of something...
Great job if you managed to get the engine intake to work! I previously tried a similar concept and could not get enough air into the engine.
Just hand them in however you prefer.
I just updated you, so now you can download the newest software. Good luck.
Looks good as always. Interesting rear wing.CAEdevice wrote: ↑Thu Aug 09, 2018 6:31 amSorry but I could not fid the time to paint the car, anyway this is the car I have just submitted:
http://www.caedevice.net/SERVER/MVRC/20 ... ne_001.JPG
I need a double airfoil to balance the car despite the low DF setup, not a good sign...Ft5fTL wrote: ↑Thu Aug 09, 2018 1:40 pmLooks good as always. Interesting rear wing.CAEdevice wrote: ↑Thu Aug 09, 2018 6:31 amSorry but I could not fid the time to paint the car, anyway this is the car I have just submitted:
