2018 Belgian Grand Prix - Spa Francorchamps, 24-26 August
gastonmazzacane
Re: 2018 Belgian Grand Prix - Spa Francorchamps, 24-26 August
So...can a Ferrari pass Mercedes on Kemmel straight on normal terms(No Merc driver errors on Raidillon or La Source...etc)?
F1NAC
164
GPR-A wrote:
25 Aug 2018, 18:21
F1NAC wrote:
25 Aug 2018, 18:17
According to Vettel he run out of battery on the last lap
Despite their battery trick? :D
I guess it was the same for most people, because everyone was trying to do back to back laps without cooling lap where they recharge the battery.
Don't know about others but from LCD info on his steering wheel it was visible that at the beginning of his last lap he had very little energy left. 1/6 maybe
Gr1ff
Gr1ff
I hope one day Hamilton will drive for Ferrari so he will finally be appreciated.
Great qualifying. I hope there will be a good battle between Seb and Lewis tomorrow.
LM10
LM10
120
F1NAC wrote:
25 Aug 2018, 20:39
GPR-A wrote:
25 Aug 2018, 18:21
F1NAC wrote:
25 Aug 2018, 18:17
Yes, Vettel told that at Eau Rogue he already felt power deficit.
Still, he could or must have made that time loss up in S2 in better track conditions. However, according to Vettel, his Inters were quite done.
LM10
LM10
120
Gr1ff wrote:
25 Aug 2018, 20:40
Most people, including me, know and appreciate his wet driving skills. Hamilton is simply the best out there. I know that for myself, but don’t feel the need to tell it on here 100 times. That’s why I’m being hated a bit, I guess. :)
LM10
LM10
120
NathanOlder wrote:
25 Aug 2018, 19:01
LM10 wrote:
25 Aug 2018, 16:37
thetruth wrote:
25 Aug 2018, 16:34
Imagine if in the turn where Lewis went wide,was gravel and not asphalt.
Hockheneim 2.0
Good catch. But his fans probably won't consider that. :)
When im racing in Karts in the wet, i push harder on corners with tarmac run offs as apposed to gravel or grass run offs. Im sure im not the only driver in the world. Just saying :roll:
This sounds plausible. I don’t know to which extend a world class driver like Hamilton decreases his maximum potential, knowing that their is asphalt instead of gravel, but I agree with what you tell. He most probably adjusted his driving.
Bill_Kar
Bill_Kar
Quick question :is it possible to change things like wing angle after quali?
F1NAC
164
Bill_Kar wrote:
25 Aug 2018, 20:55
Ye during pitstops
Another question. Will Bottas start on set used in Q2 after he progressed into Q3?
siskue2005
70
F1NAC wrote:
25 Aug 2018, 20:56
Bill_Kar wrote:
25 Aug 2018, 20:55
Ye during pitstops
they can change the front wing angle, tyre pressures etc before race, there are other small things which u can adjust in the parc ferme
zibby43
zibby43
613
So he lost "only" 4 tenths in S2 while enjoying better track conditions than Hamilton had. Not that impressed by that particular tidbit.
Schuttelberg
Gr1ff wrote:
25 Aug 2018, 20:40
Hamilton doesn't need to be a Ferrari driver to be appreciated. He has driven an entire career at an incredible level. Formula 1 fans have a habit of being drowned in nostalgia and putting down current drivers. Once Hamilton and Vettel retire, we're going to appreciate what we're watching at the moment. It is the stuff of legends!
search
F1NAC wrote:
25 Aug 2018, 20:56
Bill_Kar wrote:
25 Aug 2018, 20:55
Ye during pitstops
yep, same as everyone else who progressed into Q2
edit: into Q3 of course
Shrieker
Juzh wrote:
25 Aug 2018, 18:30
gotta love this save by perez on slicks in q3 :shock:
https://streamable.com/z45u8
Man, that IS hairy af. He's lucky he had a slide before going into eau rogue as he was turning in. Otherwise he could've found himself completely out of control and slamming into the barriers on the left while going thru the left - right transition past ea rogue. Actual he almost did slam, he was right on the cusp of loss of control for a good while - but well held in the end !
Pants were most likely replaced tho :D
-Atatürk
subcritical71
90
search wrote:
25 Aug 2018, 23:02
F1NAC wrote:
25 Aug 2018, 20:56
Bill_Kar wrote:
25 Aug 2018, 20:55
Ye during pitstops
What’s the penalty of he puts new tires on? (Back of the grid?)
