Mercedes AMG F1 W09 EQ Power+
siskue2005
70
Re: Mercedes AMG F1 W09 EQ Power+
is the nosel behind fed from the air catch for the brakes?
zibby43
zibby43
zibby43
zibby43
This looks like a photo from in-season testing. Double pylon and max downforce spec. Doesn’t match the photos coming out of Sochi. I reserve the right to be wrong though hah!
zibby43 wrote:
27 Sep 2018, 17:00
It's from Sochi, they have the spoon and this one there.
If you look at the endplates you'll see it's the newest model.
siskue2005
70
so finally they are going for swan neck ever since this new aero formula started from 2014.
zibby43
zibby43
Sevach wrote:
27 Sep 2018, 18:15
zibby43 wrote:
27 Sep 2018, 17:00
https://imgr4.auto-motor-und-sport.de/M ... 191205.jpg
https://imgr2.auto-motor-und-sport.de/M ... 191206.jpg
https://imgr3.auto-motor-und-sport.de/M ... 191202.jpg
That’s a heck of a spot by you my friend! That’s a fairly decent upgrade/change in that area.
Thanks for the clarification.
What’s the primary benefit of this configuration?
https://twitter.com/albertfabrega/statu ... 58053?s=21
Cleaner flow under the wing?
mantikos
mantikos
35
godlameroso wrote:
27 Sep 2018, 20:17
They dual supports act like a wing fence essentially
zibby43
zibby43
mantikos wrote:
27 Sep 2018, 20:18
godlameroso wrote:
27 Sep 2018, 20:17
Wing fence?
siskue2005
70
godlameroso wrote:
27 Sep 2018, 20:17
yes there is not risk of flow detachment under the wing and better in yaw conditions and cross winds etc in this configuration
djones
djones
Looks like they were holding off on updates until they got the fundamental issues sorted.
And now they seem to have fixed the tyre heat/wear issues its good to see things like new wings.
zibby43 wrote:
27 Sep 2018, 19:54
Thanks.
Swan neck (attaching at the top rather than underneath) causes less disruption underneath the wing (well duh).
Double vs single is structural, weight of a large support beam vs 2 slimmer ones... maybe less side movement...
jh199
32
Is that a downwash wing in between the two swan neck mounts? Right where the mounts change from smooth black to a carbon weave.
NoDivergence
NoDivergence
50
Yes, there is a downwash wing between the mounts. Possibly to influence the exhaust to be more level than going upward? This could improve diffuser performance
