Big Tea
J.A.W. wrote:
01 Oct 2018, 01:00
See here: https://www.youtube.com/watch?v=YEaE6BHyjzg
2-piece piston designed to reduce mass & improve dimensional-control/sealing - via even thermal expansion.
Brilliant, as long as it does not unscrew :D
gruntguru
gruntguru
563
Pinger wrote:
26 Sep 2018, 17:47
. . . . Any backpressure incurred by a PRT would require a corresponding increase in scavenging pressure - a near impossibility with the crankcase as transfer pump. Equally hard to imagine a PRT could be contrived to harness the pulse energy without creating backpressure. . . .
There are many examples of crankcase scavenged 2 strokes adapted for turbocharging.
If you read the Wright T.C. info you can see how its done.
Pinger
Pinger
gruntguru wrote:
02 Oct 2018, 06:06
Yep, with 2-stage supercharging (and yes, altitude performance was a factor also).
I think we can safely conclude there has never been a NA 2T engine with a PRT - and probably never will be.
gruntguru
gruntguru
563
No - my point was - a PRT can be configured in a way that captures blowdown energy without creating backpressure during parts of the cycle that would be disadvantageous (with or without supercharging).
tok-tokkie
tok-tokkie
36
That 2 piece piston design. Here is a guy who wants to combine that idea with another that allows a piston ring that is a complete ring. The screwed piece is the complete crown with the wrist pin bit as in the 2 part design. Just the simple cylindrical skirt screws onto the crown. The skirt traps the complete piston ring in its groove. Seems a really good idea to me. What about expansion of a complete piston ring - is that an issue?
https://www.youtube.com/watch?v=JGK-Sa8 ... e=youtu.be
Pinger
Pinger
gruntguru wrote:
03 Oct 2018, 06:20
How can it be so configured - much larger than required/expected relative to the mass gas flow?
Pinger
Pinger
tok-tokkie wrote:
09 Oct 2018, 18:06
Struggling to see how an unsplit ring can expand under gas pressure to perform its sealing function.
63l8qrrfy6
63l8qrrfy6
368
The same way a C ring does in static sealing applications I suppose.
gruntguru
gruntguru
563
Pinger wrote:
09 Oct 2018, 19:20
gruntguru wrote:
03 Oct 2018, 06:20
Basically - yes. Of course the exhaust runners must be grouped to avoid overlapping of exhaust events within each group and plumbed to deliver blowdown pulses all the way to the turbine nozzle (which will be the smallest cross section in the runner).
Pinger
Pinger
gruntguru wrote:
10 Oct 2018, 01:21
With such a configuration, would the pulse be reflected on/after entering the turbine nozzle and if so, would it reflect as a positive or negative pulse?
gruntguru
gruntguru
563
Pinger wrote:
16 Oct 2018, 21:12
gruntguru wrote:
10 Oct 2018, 01:21
https://books.google.com.au/books?id=MD ... ne&f=false
Any reflection is an indication that the turbine is not extracting all the energy from the pulse. The linked article states that reflections increase with pressure ratio and pulse turbocharging becomes less viable at high pressure ratios. The reflections are positive - having a negative effect on the exhaust stroke.
Pinger
Pinger
Thanks GG - much appreciated.
manolis
manolis
107
Hello all.
Here are the moving parts of the OPRE TIlting 2-stroke engine:
The above tilting valves have "rectangle" shape for the shake of the easy / accurate manufacturing with a lathe.
And here are two youtube videos of the engine (manual cranking).
Thanks
Manolis Pattakos
tok-tokkie
tok-tokkie
36
I am really pleased to see your progress into running engine. It sounds very smooth & there is no vibration. Looking wonderful. Congratulations.
Pinger
Pinger
As per the above post Manolis, congrats on getting it built and running. A few questions if you can indulge me please.
Looking at the designated web page, I see some of the claimed benefits (eg, combustion dwell, side thrust on cooler part of piston, etc) but what does the tilting valve bring to the table? Asymmetric timing and if so, in which direction - late? What are the transfer and exhaust timings (if you are prepared to divulge them - fine if you prefer not to)? When do you intend to run it under load and what power output are you expecting?
