Brilliant, as long as it does not unscrewJ.A.W. wrote: ↑Mon Oct 01, 2018 12:00 amSee here: https://www.youtube.com/watch?v=YEaE6BHyjzg
2-piece piston designed to reduce mass & improve dimensional-control/sealing - via even thermal expansion.
There are many examples of crankcase scavenged 2 strokes adapted for turbocharging.Pinger wrote: ↑Wed Sep 26, 2018 4:47 pm. . . . Any backpressure incurred by a PRT would require a corresponding increase in scavenging pressure - a near impossibility with the crankcase as transfer pump. Equally hard to imagine a PRT could be contrived to harness the pulse energy without creating backpressure. . . .
If you read the Wright T.C. info you can see how its done.Equally hard to imagine a PRT could be contrived to harness the pulse energy without creating backpressure.
How can it be so configured - much larger than required/expected relative to the mass gas flow?
Struggling to see how an unsplit ring can expand under gas pressure to perform its sealing function.tok-tokkie wrote: ↑Tue Oct 09, 2018 5:06 pmThat 2 piece piston design. Here is a guy who wants to combine that idea with another that allows a piston ring that is a complete ring. The screwed piece is the complete crown with the wrist pin bit as in the 2 part design. Just the simple cylindrical skirt screws onto the crown. The skirt traps the complete piston ring in its groove. Seems a really good idea to me. What about expansion of a complete piston ring - is that an issue?
https://www.youtube.com/watch?v=JGK-Sa8 ... e=youtu.be
Basically - yes. Of course the exhaust runners must be grouped to avoid overlapping of exhaust events within each group and plumbed to deliver blowdown pulses all the way to the turbine nozzle (which will be the smallest cross section in the runner).
With such a configuration, would the pulse be reflected on/after entering the turbine nozzle and if so, would it reflect as a positive or negative pulse?
https://books.google.com.au/books?id=MD ... ne&f=false
