2018 aero developments
jjn9128
785
Re: 2018 aero developments
Big Tea wrote:
24 Jul 2018, 13:10
So where are the titanium skid blocks on there?
Just around the measurement hole on the front of the plank.
#aerogandalf
Big Tea
jjn9128 wrote:
24 Jul 2018, 15:30
Big Tea wrote:
24 Jul 2018, 13:10
Thanks, I was expecting bigger than that.
jjn9128
785
Big Tea wrote:
24 Jul 2018, 16:11
jjn9128 wrote:
24 Jul 2018, 15:30
Big Tea wrote:
24 Jul 2018, 13:10
As ever there's a long rule to describe the skid...
3.7.11 Skids
The lower surface of the plank may be fitted with flush mounted metal skids which :
a) May only be fitted in place of plank material.
b) Have a total area no greater than 20000mm² when viewed from directly beneath the car.
c) Are no greater than 4000mm² in area individually when viewed from directly beneath the car.
d) Are fitted in order that their entire lower surfaces are visible from directly beneath the car.
e) Must have a minimum cross sectional thickness of 15mm across its external boundaries in plan view.
The minimum wall thickness between an internal fixing hole and the external boundaries of the skid must be no less than 7.5mm.
f) Must have an upper surface no more than 3mm below the reference plane.
g) Must be designed such that they are secured to the car using the fasteners described in Article 3.7.12 and that, when viewed from directly beneath the car, no part of the skid is more than 50mm from the centre line of a fastener which passes through that skid.
h) Must be made from Titanium alloy.
#aerogandalf
On the Ferrari, they're around the front most measurement hole at the front of the plank. The slightly lighter coloured material.
Big Tea
Thanks both, I was expecting something far more substantial.
A nice touch to be able to see it from both sides.
Still the masters, wouldn't surprise me if they have the fastest car this weekend.
McLaren going even more aggressive with the floor slots.
MtthsMlw wrote:
26 Aug 2018, 17:54
https://pbs.twimg.com/media/DliQb-VW4AAfKq1.jpg:large
Feel bad for the ones who have to rebuild all that carnage.
Those deflectors may have potential, I fear the geometry isn't correct yet, an interesting study for next year where the rest of the chassis will have to make up for the simplified front wing.
