Scuderia Ferrari SF71H
CLKGTR
CLKGTR
101
Re: Scuderia Ferrari SF71H
Interesting, because Brembo said in March 2018 that they will offer three different Brembo disc options with approximately 900, 1200 and 1500 holes.
And now it seems that only in 19th race they offered 1400 hole disc which Ferrari first tested.
Via AMuS
dans79
267
are those supposed to be Ferrari wheels?
202 105 104 9 9 7
dans79 wrote:
08 Nov 2018, 21:59
Yup, why?
dans79
267
Morteza wrote:
08 Nov 2018, 22:00
dans79 wrote:
08 Nov 2018, 21:59
Yup, why?
I wasn't sure, so i wanted to clarify!
202 105 104 9 9 7
dans79 wrote:
08 Nov 2018, 22:01
Morteza wrote:
08 Nov 2018, 22:00
dans79 wrote:
08 Nov 2018, 21:59
Yup, why?
AMuS says they are Ferrari. They look like it too (front wheels), so I'm 99% sure they are :) I have to admit Haas has pretty similar designs too
Juzh wrote:
28 Oct 2018, 10:18
M840TR wrote:
28 Oct 2018, 08:14
I really like this setup direction they've adopted this year. Even if they're not on pole, being faster on the straights gives you a lot of breathing space with the strategy. Easy to overtake, hard to be overtaken.
https://i.redd.it/09azhfhv5su11.jpg
What I find reall odd is that all those high speed numbers were done on their ultra soft run in Q2. In Q3 they were down 8 kmh on the main straight.
q2 on the left, q3 on the right
https://i.imgur.com/3EUaPQZ.jpg
Anyone have a clue what's going on here?
Way late...
Wind direction?
M840TR
M840TR
315
According to Italian motorsport Ferrari is testing for a revolutionary cooling system for 2019 to make the sidepods even thinner.
In the first free practice session of the Brazilian GP, ​​Ferrari carried out fluid dynamics tests on the sides, mounting six sensors in the bellies to simulate a 2019 system that should allow particularly tight sides.
Ferrari did not try any time in the first free practice session of the GP of Brazil, but the team of the Cavallino worked hard to bring home useful results to the definition of what will be the car of 2019. The technicians directed by Mattia Binotto are studying the new bellies for the 670, that is to say the car next year which for now is only identifiable by the project number.
Enrico Cardile and David Sanchez, the aerodynamics that two years ago had invented on the SF70H a new concept to draw the sides, moving the radiator's mouths farthest from the front tires, avoiding the harmful effects of the turbulence generated by the wheel in motion.
The idea of ​​2017, then copied by many teams this year, will almost certainly be revolutionized on the Red of 2019 and it is rumored that Ferrari could bet on even narrower sides with a different cooling system. It is for this reason that a rake of sensors was also mounted inside the sides that have been modified in their fluid dynamics.
The two SF71Hs shot in different configurations just to give answers to the Maranello technical office. The skilled Albert Fabrega managed to catch the moment when they could see the sensors under the Ferrari body.
The camera, on the other hand, was seen at the bottom of the floor and was used to monitor the flow directed towards the diffuser and the flow diverters that reappeared on the floor near the tracks.
Via Albert Fabrega
https://it.motorsport.com/f1/news/ferra ... 10884/amp/
How does the author get from sensors inside the engine cover to a revolutionary cooling system for 2019?
Still interesting though.
GPR-A
37
Blistering on Vettel's Ferrari.
LM10
LM10
122
M840TR wrote:
09 Nov 2018, 19:18
https://pbs.twimg.com/media/DrkDl-7W4AAucGY.jpg:large
https://cdn-3.motorsport.com/images/amp ... tail-1.jpg
Via Albert Fabrega
Very interesting.
How do they analyze a possible revolutionary cooling system by mounting sensors into the inside of the current cover, as seen on the upper picture?
Perhaps they're trying to confirm the airflow/temperature profile inside the sidepods compared to a CFD model. A bit like they do with aero rakes on the outside.
zibby43
zibby43
https://twitter.com/AlbertFabrega/statu ... 6463033345
Ferrari experiencing some significant blistering on the SS.
M840TR
M840TR
315
Those are likely to measure air inside the engine cover and get an idea of the breathing space to evaluate how far they can push the packaging.
