HALO Approved for 2018
aral
aral
Re: HALO Approved for 2018
I started to remove some posts as this debate between seat belts and Halo were getting ridiculous and rather pointless. The halo was approved and mandatory for 2018 and will still remain so for the forseable future. Will it save lives or serious injury? Most likely, but continuing the argument , contrary to expert opinion, is not going to change the rules.
More posts deserve to be removed , and are likely to be.
Please move on to 2019.
strad
271
henry wrote:
Fri Dec 07, 2018 8:53 pm
What people do for their own entertainment and what people require others to do in order to provide vicarious thrills are two entirely separate and different things.
No body requires anyone too drive and never has.
Sir Stirling Moss
Bence
Bence
The halo is a latent potential killer.
As long as the gap between the arc of the halo and the cockpit is large enough to trap a nosecone and guide it towards the head/helmet of the driver, there is no such thing as protection in this case. Either the head rotates away, or the nose parks in right through the visor.
Scorpaguy
Scorpaguy
The HALO is going to save lives and cost lives...the ratio of such is yet to be determined. What I do not look forward to is that bad situation when the inability to self extricate creates a horrible optic of a visibly struggling, but trapped driver. However, we can be assured that if such does happen, the FIA will aver the driver would have suffered multiple deaths prior to his struggling had the HALO not been in place.
Jolle
Jolle
199
Bence wrote:
Sun Dec 09, 2018 12:44 am
We had this nosecone on the head thing at IndyCar, without halo. His head did rotate away! Snapped his neck in the process.
henry
306
strad wrote:
Sat Dec 08, 2018 8:48 pm
I was using require in its sense of needing or expecting, not commanding or instructing. I well no that no body, or nobody, forces them.
Bence
Bence
Jolle wrote:
Sun Dec 09, 2018 10:18 am
Justin Wilson died of traumatic brain injuries, not because of a snapped neck...
But imagine when you sit in the car, you are stationery after the accident and the other car comes from the opposite direction at an angle, goes airborne and would normally fly over your head, but the halo catches the nosecone, the nose slides under the halo and your fate is sealed. Nowhere to go, your pupils go wide as time slows down in the moment of the accident and you realize, that was it. It can be a freakishly low speed accident, but the forces are enough to twist or crack a neck or skull.
strad
271
Bence wrote: ↑
Sat Dec 08, 2018 4:44 pm
Even I have a hard time picturing that one. Are our noses pointy enough to fit between the HALO and the cowl?
Sir Stirling Moss
Jolle
Jolle
199
Bence wrote:
Sun Dec 09, 2018 8:31 pm
If, after a big accident I’m in the opposite direction with cars flying towards me, I definitely want a halo!!
adrianjordan
67
The HANS would offer considerable protection for a driver's neck, it would have to be a very freakish accident for a driver to suffer a broken neck, let alone a fatal (or even paralysing) spinal injury....not saying it couldn't happen, but it is unlikely in the extreme.
As for head injuries, that's what helmets are for. I don't know, but I suspect there is a lot of ongoing research into improving the protection offered by the helmets.
Of course the best solution in your example would be a HALO with screens in between the chassis and the upper bar...but then you have issues of visual distortion that the drivers don't seem to be able to cope with.
Since I've ordered an electric car, does that mean I should start watching Formula E?
Big Tea
126
adrianjordan wrote:
Thu Dec 13, 2018 1:19 pm
I know its very 'Star Trek' and I do not know how good the optical qualities are, but thy are 'talking about' safety glasses made of it.
http://www.surmet.com/technology/alon-optical-ceramics/
I am very much in favour of filtered water. Preferably passed through a brewery
FW17
232
Today the debris flying around made quiet an impact.
Wonder if FIA will further improve on the halo
El Scorchio
Is that the debris that ripped Hamilton's wing mirror off the car? Extremely lucky it didn't enter the cockpit. It would have done a lot of damage, halo or no halo.
izzy
69
FW17 wrote:
Sun Oct 13, 2019 1:40 pm
https://www.sportvideos.tv/wp-content/u ... .39.11.png
yes halo isn't 100% is it, and yes i bet FIA are watching the Indy screen. but in probability terms Halo is more effective than you might think at first glance: not many things will miss the centre strut completely and yet hit the helmet at all square. Most things will at least partly hit the centre strut or glance off the rounded side of the helmet
and in exchange Halo skips all the problems of the screen with spray getting on the inside and muck on the outside and sun on it and all that
El Scorchio
To be truthful this is on the stewards rather than the pros and cons of halo vs screen or otherwise.
Leclercs car should have been flagged straight away. That's the one bulletproof way of avoiding the incident in this circumstance.
