[MVRC] Mantium Virtual Racecar Challenge 2018
etsmc
etsmc
Re: [MVRC] Mantium Virtual Racecar Challenge 2018
Yes Variante is certainly looking like a sure thing for the championship, he already has alot of development and understanding under his belt with what he was doing here viewtopic.php?f=14&t=27159
I am interested to see what sort of number people will be getting on their first car and how they progress. Also the gap between the top 3 and the rest of the field.
Will we see the cars producing more or less downforce than the LMP style cars and will we see the efficiency up there?
CAEdevice
40
etsmc wrote:
Tue Apr 02, 2019 4:37 am
I am sure the cars will produce less downforce and will be much less efficent (top teams from cl/cd around 7 to cl/cd around 3.7 or less considering the KVRC F1 cars)
LVDH
30
etsmc wrote:
Thu Mar 28, 2019 3:47 am
How can I see the flow on a monitoring surface just like you have on the linked page?
https://mantiumchallenge.com/wp-content ... g_flow.png
It is pretty simple. You have to open up the stlSamples file in the system folder of your case. There you change
Code: Select all
surfaceFormat null;
to
Code: Select all
 surfaceFormat vtk;
and
Code: Select all
writeFields     false;
to
Code: Select all
writeFields     true;
Then you execute this command in the case folder:
Code: Select all
mpirun -np $nCPUs simpleFoam -postProcess -latestTime -parallel
You will then find vtk files in the postProcessing folder in the folders corresponding to the surfaces.
Is it possible to have this done in post-processing?
Yeah, no problem.
Today Richard sent me his first version of the CAD parts for the new season. There is still some work that needs to be done, but it was fantastic to see the first F1 parts on my computer this morning. It should not take too long for us any more to provide you with a first set of rules, so you can start designing.
etsmc
etsmc
LVDH wrote:
Tue Apr 02, 2019 8:48 am
Code: Select all
surfaceFormat null;
to
Code: Select all
 surfaceFormat vtk;
and
Code: Select all
writeFields     false;
to
Code: Select all
writeFields     true;
Code: Select all
Yeah, no problem.
:o cool thanks. This is awsome should help with development. So close i can feel that sense of dissapointment after the first race and i am so far behind. . :D
machin
187
etsmc wrote:
Tue Apr 02, 2019 11:46 am
Positive attitude! :D
On a different topic: Now I've had a play with it I can confirm the statements made by Matteo and others: FREECAD seems to be a really good free alternative to Solidworks.... definitely recommended to anyone who wants to have a go at Parametric modelling...
CAEdevice
40
machin wrote:
Thu Apr 04, 2019 1:03 pm
Yes, it is free and open source. The new assembly workbench (after release 0.18) is very promising (assembly has always been a weak point of FreeCAD). Parametric CAD is a bit slower when we start a model from zero, but it improves "fine tuning" process very much.
There is an interesting CFD module (very rough, nothing to do with MantiumFlow refined settings about mesh, rotating wheels, turbolence models) but enough for a quick check during the very early part of the design.
https://www.freecadweb.org/wiki/Sandbox:CFD
Alonso Fan
45
Thanks for the info
Definitely intend to have a look into this
MVRC - SHM Racing
LVDH
30
Richard got a hang of FreeCAD pretty quickly and his model look quiet good now. If you guys want we can release the FreeCAD as well as the step and stl files as soon as we are "done".
I am not sure it is the best way to design a car. I am intending to release a video about designing a car in Blender. With Blender it is much easier to create crazy shapes and the stl files are later really nice.
CAEdevice
40
I am curious aboit the difference between Formula M and Formula 1 rules. We will have a stepped floor? The rear wing and engine cover will have that mandatory surfaces only useful for the sponsors?
machin
187
Essentially it will be VERY close to F1 rules.... but instead of the complicated rule book we have a quite detailed set of volumes which you must keep within; that stops you from straying too far from a real F1 car. In the current draft of the rules we have a stepped floor; 90% of the floor will be a given part which you can’t change... Andre and I will be making the final tweaks very soon...
CAEdevice
40
machin wrote:
Fri Apr 05, 2019 12:55 pm
Good idea. But you will include the diffuser too?
The template and the "3D rulebook" will be provided only as STL or also as STEP?
machin
187
As Andre suggested above; I think the files will be released as STEP, STL and FreeCAD.
I don’t want to say too much about the details about the rules until I’ve discussed them with Andre... but we are pretty close!
CAEdevice
40
machin wrote:
Fri Apr 05, 2019 1:31 pm
FreeCAD native! Thanks! =D>
Alonso Fan
45
Just checked out freecad. I'm sold...
... I know I know its free
It's good that the rules are new. I don't have to go round looking for ways to port sketchup models to freecad now. And designing an f1 car shape will be much easier than the lmp cars were. Always struggled with those front fenders in solidworks
MVRC - SHM Racing
rjsa
rjsa
69
Have a look at fusion360. It’s free if you say you’re a hobbist.
It has TSplines, that will work much like the subdivision surfaces on blender.
