Scuderia Ferrari SF90
vogonvader
vogonvader
Re: Scuderia Ferrari SF90
Bill wrote:
Sun Jun 09, 2019 12:18 pm
According to Toto Mercedes built a car with a lot of downforce but with a drag penalty to make tyres to work and get the most out of them Ferrari had done the opposite this explains the difference in top speed between to teams
Hasn't this already been talked over a thousand times since the season began? Do we really need the same deduction yet every weekend?
bosyber
bosyber
siskue2005 wrote:
Sun Jun 09, 2019 10:18 am
bosyber wrote:
Sun Jun 09, 2019 10:03 am
The comparison video from Q3 indicates Vettel loses in the early (breaking phase?) of the slower corners, doesn't it?
From the graphics, he loses as soon as we brake for the corner and also continues to lose time (until the corner exit when the traction out of the corner is no longer dependent on mechanical suspension/downforce and pure engine power kicks in.)
You can verify that in the video below (btw great comparison)
[CUT out the very video I was talking about]
No need to verify what I already saw, and commented on, right (we? eh, right)?
Anyway, what I meant, was, as seen from that video, is indeed that Vettel starts losing from braking into the corner; not that he stops losing after that; but from the 'Ferrari loses in the slow corners' I didn't get that they were losing so much already during braking - makes sense that then he's much slower going into it so loses until he can get onto the power.
TheFluffy
TheFluffy
siskue2005 wrote:
Sun Jun 09, 2019 11:26 am
TheFluffy wrote:
Sun Jun 09, 2019 11:15 am
Admittedly, the source of Mercedes having a more fuel efficient engine is from last year (I think it was amus) but it did say (at least for last year) they had a more efficient ICE. Of course, lots can change but extrapolating from last year's knowledge maybe it remains status quo.
Also, this is a very superficial observation, but the crazy packaging that Mercedes are able to achieve with their car may be down to having an efficient engine. Of course, it is probably predominantly because of their better cooling system. But efficiency MAY play a part.
So based on just the fuel efficiency which was reported in 2018 you are saying Mercedes still the best engine?
1. even when ferrari can run higher engine modes through out the weekend,
2. even when ferrari can go faster in mid straights
https://serving.photos.photobox.com/549 ... 35c588.jpg
3. even when ferrari can have letter boxes as their sidepod entry for last 2 years
4. even when ferrari can pull out 0.3 sec just in one straight
https://serving.photos.photobox.com/653 ... dd718c.jpg
5. even when other ferrari powered teams are also power full
Still Mercedes engine is better than ferrari's!?
Right!!
Firstly, if you look at my initial comment I only said that the discussion can not be put to bed. I am recognising there are clear advantages in Ferrari's engine, but you are neglecting the advantages that Mercedes may have over the Ferrari. So I don't think the advantages that Ferrari have atm can absolutely outweigh the disadvantages it may have.
Furthermore, I feel like you are exaggerating how small Ferrari's sidepod inlet (especially since they increased the size of it to accommodate the smaller airbox) Mercedes is still one of the smallest on the grid. Furthermore it seemed you ignored my point about packaging, because Mercedes' packaging is second to none.
Also generally, Ferrari since 2018 has adopted a low-drag concept (unlike Mercedes) with their car so it makes sense that they can have the top speed and gain time on sector 3.
CLKGTR
CLKGTR
92
Vettel and Leclerc 1-2 in 3 out of 4 speed measurements, but only 5 km/h between 2nd and 19th top speed on the longest straight
2019 Canadian GP – Qualifying – Ferrari sets top speed standard in all sectors
SmallSoldier
SmallSoldier
312
Found the following picture, which I think it’s from one of the FP sessions (FP3)... Is Ferrari running different brake drums left/right?...
SmallSoldier wrote:
Sun Jun 09, 2019 2:42 pm
https://uploads.tapatalk-cdn.com/201906 ... 5fbb06.jpg
Yes it's quite a common practice. Sometimes just for comparisons or for heating the tyres differently depending on the circuit.
SmallSoldier
SmallSoldier
312
Thanks... First time I noticed
Tzk
Tzk
25
All teams do this because not all circuits put equal load on the left and right tires.
Carl Mccoy
Carl Mccoy
-6
Maybe Monza? ☺
DiogoBrand
96
Tzk wrote:
Sun Jun 09, 2019 10:11 pm
I'm not sure that's the reason. Unless you're locking up a wheel, the load on both brakes should be the same.
I think @MtthsMlw 's explanation makes more sense, that they would do this only to test both solutions and find out which one is the best for the situation.
vogonvader
vogonvader
Now that the heat dies down a little, I wonder if Austria and France can turn out 2 other tracks where Ferrari might pull off another Canada? They both have long straights for Ferrari to take advantage of.
dans79
dans79
383
vogonvader wrote:
Mon Jun 10, 2019 5:00 pm
if the heat dies down it'll be the opposite, Ferrari has a problem keeping heat in the tires not overheating them.
172 101 99 7
timbo
timbo
122
I think they have a good chance in Austria, especially with the right weather. Not sure about France, they were not on the pace there last year.
f1316
f1316
135
Agree re Austria - I think the key for France and any other circuits that are less stop/start/full throttle is what they’re bringing in terms of front wing (which apparently is slated for Paul Ricard).
If they’re able to get more front downforce without compromising their overall concept - and can therefore better balance the car + get tyres in the window - I think they may have a chance; there’s lots of on throttle in France/Britain which could be good presuming they can get rid of the huge understeer they have.
zibby43
zibby43
653
f1316 wrote:
Tue Jun 11, 2019 4:14 pm
If they’re able to get more front downforce without compromising their overall concept - and can therefore better balance the car + get tyres in the window . . .
In other words, if they are able to completely rectify all of their problems.
