2019 Mclaren F1 Team - Renault
Re: 2019 Mclaren F1 Team - Renault
M840TR wrote:
10 Jun 2019, 19:50
diffuser wrote:
10 Jun 2019, 19:35
M840TR wrote:
10 Jun 2019, 14:06
It's quite front limited indeed. Sort of like Barcelona. Judging by the pattern so far the performance will probably be quite bad. Renault is bringing a substantial upgrade as well while still being a bit ahead on pace currently, so the outlook looks bleak in terms of pace.
It all depends on how accurate some of the speeds are. It isn't clear to me if McLaren are front end limited at slow speeds and not so much at high speed.
There was talk about removing turns 8 and 9 from the 2019 configuration last year.
https://cdn-1.motorsport.com/images/mgl ... ck-map.jpg
Understeer mostly hits at high entry speed, doesn't matter if the corner is slow or fast.
You can generate more DF at Higher speeds.
Ground Effect wrote:
10 Jun 2019, 18:03
godlameroso wrote:
10 Jun 2019, 16:56
_cerber1 wrote:
10 Jun 2019, 08:34
French track is limited in front? It seems that this is not very suitable for our chassis.
Its front limited in the final 3 curves which are long and low speed. All other corners have relatively fast entries, save the slowest turn which leads onto the back straight.
Alonso managed to score points there last year. They can do it again with a trouble free weekend. The car is fast enough to finish every race in the points, and getting better every round. There are still costly operational errors holding them back.
Alonso was a DNF at Paul Ricard last year.
Was thinking of Austria sorry.
M840TR
M840TR
315
diffuser wrote:
10 Jun 2019, 20:06
M840TR wrote:
10 Jun 2019, 19:50
diffuser wrote:
10 Jun 2019, 19:35
Not with the tapered front wing.
charliesmithhd
charliesmithhd
67
M840TR wrote:
10 Jun 2019, 22:01
diffuser wrote:
10 Jun 2019, 20:06
M840TR wrote:
10 Jun 2019, 19:50
Do you think mclaren are working on a red bull/merc front wing, as James key said that style is the optimal
SmallSoldier
SmallSoldier
488
charliesmithhd wrote:
M840TR wrote:
10 Jun 2019, 22:01
diffuser wrote:
10 Jun 2019, 20:06
I’m sure they are evaluating it, the problem is whether that type of wing would work with the rest of the package... There is interaction between the front wing, the suspension and the bargeboards... The current setup is designed to work with the flow of air that the current wing generates, it would be a very drastic change to go for a different wing concept.
The current concept seems to be working well, of course there’s still a lot of development needed, but it was really impressive to watch Sainz go for 60+ laps on the hard tires and maintain a very steady rhythm throughout that whole stint.
charliesmithhd
charliesmithhd
67
SmallSoldier wrote:
10 Jun 2019, 22:12
M840TR wrote:
10 Jun 2019, 22:01
But to make that push to the top 3 surely they’ll need something big like this, refining what they have may not
M840TR wrote:
10 Jun 2019, 22:01
diffuser wrote:
10 Jun 2019, 20:06
M840TR wrote:
10 Jun 2019, 19:50
The faster the air passes over that wing the More DF that wing will create. The rate it increases may or may not be at the same rate as other wings but it still increases. Don't say no.
Shots From Monaco. So everyone is running max DF. Some wings Drop from middle to out on the top. some rise middle to out on the bottom. I'm not certain that the FW or the requirement by the aero that cause it to need this type of FW is McLaren weakness. They were very competitive in Monaco's in the first sector( 1/10 behind the 2 RBRs). The section where Sainz passed the 2 STRs.
SmallSoldier
SmallSoldier
488
SmallSoldier wrote:
10 Jun 2019, 22:12
charliesmithhd wrote: Do you think mclaren are working on a red bull/merc front wing, as James key said that style is the optimal
I don’t think any of us really know... Red Bull has a very similar front wing concept (as does Williams) and they aren’t at Mercedes level... On the other hand, Ferrari has a very similar concept to McLaren and they are closer to Mercedes than anyone else.
I’m sure that the team has enough data on hand to make the best assessment and future upgrades will let us know if they are going in the right direction or if they decide to change the concept.
The front wing by itself won’t make all the difference unluckily.
SmallSoldier wrote:
11 Jun 2019, 03:43
SmallSoldier wrote:
10 Jun 2019, 22:12
Exactly what I was trying to say with the pictures.
_cerber1
301
Giorgio Piola said
Andres125sx
mwillems wrote:
10 Jun 2019, 13:43
Andres125sx wrote:
10 Jun 2019, 08:21
So brakes problems on both cars, presumably both due to debris blocking air intakes, compromised Carlos race forcing to do 67 laps on same tires, and melting Lando suspension. It´s a shame since McLaren was performing really well this weekend
Some will say drivers did underperform again tough :roll:
I'm not sure anyone has looked at mechanical failures / issues and blamed the drivers, it's just you putting that out there I think, but if it suits you're narrative then i dont mind 😊
Well, you said he ruined 3 races himself even when you can´t provide a reason for the third (first two are laughable btw), but keep blaming him so... :roll:
mwillems
Andres125sx wrote:
11 Jun 2019, 07:56
mwillems wrote:
10 Jun 2019, 13:43
Andres125sx wrote:
10 Jun 2019, 08:21
Once more misquuoting. I said he compromised, not ruined, seems you have a little agenda.
-Bandit
M840TR
M840TR
315
diffuser wrote:
10 Jun 2019, 22:37
M840TR wrote:
10 Jun 2019, 22:01
diffuser wrote:
10 Jun 2019, 20:06
Apologies for the brevity. What I meant is the tapered FW does not generate more downforce at higher speeds than the conventional. Of course any object passing through air has higher resistance with increase in speed, but relatively speaking the tapered FW doesn't generate the upwash that the other one does. Which is why the front end isn't as agile. F1 is all about relative performance; so for instance it wouldn't matter if a new car isn't as quick as the old one as long as it's better than the competition that year. Obviously the same applies to low-speed corners but aero usually isn't as significant in such scenarios.
The comparison to SF90 isn't as straight forward either. Sure the car is much better overall than the Mcl34 but that's not to suggest they don't share similar limiting factors because of mutual FW philosophies. Both have front-end DF issues which is a fact. Where the former excels is better aero (NB: Ferrari has an S-duct unlike Mclaren), mechanical and tyre management. If Mclaren keep developing the concept they'll probably reach similar performance levels but theoretically the ceiling is much lower to the front.
_cerber1
301
