garygph wrote: ↑Tue Jul 02, 2019 9:38 am
godlameroso wrote: ↑Mon Jul 01, 2019 9:12 pm
Heat affects aero in a minimal way as the heated air over the asphalt is thinner than the air a few inches higher.
Agreed and the floor is working with that layer of hot air. Has the air density, between the hot asphalt and higher altitude, been that low this year yet? Genuine question btw.
Yes it has. Using an average circuit altitude of 753m I used these variables to get the difference in density altitude between 2018 and 2019:
2018
Air temperature - 24C
Altimeter setting - assumed standard altimeter setting of 1013mb
Dew Point - 15C (also assumed looking at past data)
Density altitude = 4311ft/1314m
2019
Air temperature - 36C (couldn't find he actual readings but this was the closest forecast)
Altimeter setting - 1013 (assumed standard as above)
Dew Point - 20C (assumed looking at previous data)
Density altitude = 5704ft/1739m
That 1400ft difference will be quite noticeable.
