Scuderia Ferrari SF90
Re: Scuderia Ferrari SF90
That looks like a lot more rear wing than the RedBull and Merc were showing in the Silverstone thread.
Via AMuS
NtsParadize
NtsParadize
Mission Winnow is gone :(
santos
santos
Isn't this a high downforce wing? I thought that would need less downforce at Silverstone
Ashwinv16
60
Silverstone's corners require a high downforce set-up at the rear with a looser front end as most of the corners are high speed so you want the rear to stick, except for the medium speed corners right after the left-right hander in the first sector which needs a balanced setup(Equivalent to France's third sector). The high wing means Ferrari are are confident that their car is fast enough on the straight line, so they can lose time in the first sector and gain it in the second and and third sector, knowing very well that the first sector will be problamtic for them anyway.
Halo not as bad as we thought
cplchanb
cplchanb
NtsParadize wrote:
11 Jul 2019, 17:32
it was never going to be applied here either way due to UK tobacco laws
CriXus
CriXus
95
“The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man.” - George Bernard Shaw
Zarathustra
-3
Are the rear ‘suspension-arms’ thinner as well?
Mamba
Mamba
Is that a new rear wing endplate? There is now a slot in front of the Mahle logo that was not there in the French GP update.
Xwang
Xwang
29
The new engine cover is built as a one piece only instead of two.
Doesn't seem different/modified in terms of airflow...
Maritimer
Maritimer
19
NtsParadize wrote:
11 Jul 2019, 17:32
They pulled the logos off the cars and Ducati bikes for the rest of the year.
LM10
LM10
127
Sevach wrote:
12 Jul 2019, 02:22
https://imgr4.auto-motor-und-sport.de/F ... 610563.jpg
https://imgr2.auto-motor-und-sport.de/F ... 610561.jpg
They inserted metallic parts into the floor to increase it’s rigidity. Quote out of Italian motorsport.com:
“At first glance the changes seem trivial, but the flow trend has been significantly modified also because the structure now seems more rigid as the load increases with increasing speed.”
Maybe they came to the conclusion that the flexing floor was disturbing the flow, leading to false simulation correlations.
Sempre Forza Ferrari
