Stockpiling is not possible any more. In your case only the Saturday-PU stays in the pool.aran.vtec wrote: ↑26 Aug 2019, 10:23Might be a good idea to take 2x spec 4 units for each driver on the RB team if possible, Use 1 unit on Friday and the 2nd unit on Saturday and race , Then spec 1&2 would be removed from the pool leaving them with spec 3 and 2x spec 4.
That way the 2nd spec 4 unit would be perfectly mapped and fresh for Japan. Only issue would be if spec 4 has problems
There isn't enough logic/context in your statement.mclaren113 wrote: ↑26 Aug 2019, 08:58It's not as simple as that..when you use 5 engines per year and your main competitors use 3 then you're still far behind
The happiness of Albon and his smile easily compete with Daniel R smiling.Wouter wrote: ↑26 Aug 2019, 15:54First day after the holidays now at the RB factory.
https://img2.gptoday.eu/x/artlg/5d63c20 ... 2abfe4.jpg
https://twitter.com/redbullracing/statu ... 4204487681
https://pbs.twimg.com/media/EC5SKR9WkAA ... name=small
https://pbs.twimg.com/media/EC5fusyXUAA ... name=small
I don't understand why someone need to feel provoked, if it is not a personal remark on oneself. How does criticizing a team or driver become provocative to members of this site? I don't understand that behavior.
Feel free to report any such posts to mods, whether it is from me OR from anyone else. There is a simple button to click, add comments and report.
YeahMarti_EF3 wrote: ↑26 Aug 2019, 17:41Just ignore that type of posts. Just like he said, it's not that simple. If you use 5 PU a year due reliability issues, yes, you're far behind. But if you're using 5 PU to increase the development speed of the engine, to build a serious challenge for both championships in 2020. Then it's different. As we all have seen since Austria, Honda finally unleashed serious power to be able to fight at the top.
Both STR's should take a new PU, they battle to get into the points anyway. Albon should also take a new PU, he will still need to get up to speed so it won't make much difference to him. Will perhaps somewhat take pressure off him, at the same time he can show his ability to move up the grid.lio007 wrote: ↑26 Aug 2019, 11:45Stockpiling is not possible any more. In your case only the Saturday-PU stays in the pool.aran.vtec wrote: ↑26 Aug 2019, 10:23Might be a good idea to take 2x spec 4 units for each driver on the RB team if possible, Use 1 unit on Friday and the 2nd unit on Saturday and race , Then spec 1&2 would be removed from the pool leaving them with spec 3 and 2x spec 4.
If spec 1 wasnt used any more when spec 2 was introduced yes.
