Williams started the low drag philosophy. RedBull needed it to be competitive. Ferrari mastered it.
henry
324
NL_Fer wrote:
05 Oct 2019, 21:54
Have a longer period of supercharger mode at the begin of the straight, switch to powersave/harvest mode earlier.
It is the logical thing to do, with the lower drag, giving the most advantage at the end of the straight, when at high speed. Use the ERS to balance it out and move more energy from the end tot the begin of the straight.
I don’t think that’s what the Ferrari speed traces show. They show a higher rate of deceleration before braking at the end of the straight suggesting they are charging with combined MGU-H and MGU-K.
They won’t be using any extra ERS energy at the beginning of the straight, they already have enough to do that, they will use it mid straight, perhaps from 250kph on.
Potential patterns of deployment on a straight after traction limit are:
Mercedes: e-boost - self sustain plus - self sustain - ICE only - brake
Ferrari: e-boost - self sustain plus - self sustain - harvest plus - brake
Self sustain plus (SSP)is both the H and ES feeding the K
Harvest plus (HP) is both the H and K feeding the ES. The harvest plus potentially allows a longer period of SSP.
I think this behaviour seen in this post, which confirms behaviour I observed at Hochenheim last year.
MtthsMlw wrote:
04 Oct 2019, 18:46
Comparison between Canada and Sochi
Gaining only at high speeds:
Gaining all the time..
You can see the end of straight drop off quite nicely here. On the pit straight and back straight (right before S2)
via f1analisitecnica.com
Sierra117
henry wrote:
06 Oct 2019, 10:40
NL_Fer wrote:
05 Oct 2019, 21:54
MtthsMlw wrote:
04 Oct 2019, 18:46
https://www.f1analisitecnica.com/wp-con ... 24x358.jpg
https://www.f1analisitecnica.com/wp-con ... 24x466.jpg
But shouldn't we assume that others, like Merc, have already known this? Which means they have a constraint that must be satisfied and they can't do it if they follow Ferrari's pattern.
NIKI LAUDANZ SolidarityCubolligraphy | Instagram | Facebook
#Aerogorn & #Flowramir
henry
324
Sierra117 wrote:
06 Oct 2019, 13:38
The technique I describe places a very high charge load on the ES 180kW or more. That’s hard to do. If Ferrari has a battery implementation advantage this is one way it might manifest itself.
Personally I don’t think use of the ERS is likely to be a silver bullet. This formula is unique in which a chain of small gains can yield a disproportionate overall gain.
sosic2121
henry wrote:
06 Oct 2019, 10:40
I don't want to be disrespectful in any way but I think this part is wrong.
I don't think there is any connection between harvesting and braking performance. I agree with other points that you made.
IMO greater deceleration could point to 2 explanations:
- greater DF - probably not the case;
- straighter trajectory while braking, fallowed by lower minimum speed, late apex and and straighter exit trajectory with higher exit speed.
henry
324
sosic2121 wrote:
06 Oct 2019, 18:37
henry wrote:
06 Oct 2019, 10:40
No problem with disagreeing, maybe I didn’t make my point clearly.
I’m not saying that the harvesting is affecting braking performance. I’m saying that after they reach top speed and before they brake they harvest from the K and simultaneously. The speed drops more sharply than it does for Mercedes who I think simply switch to ICE only charging the ES from the H.
This is the same phase in which in the race they lift and coast, dropping speed before braking.
At the resolution of the trace I can’t see much difference in braking performance except, as you point out, the Ferrari gets to a lower minimum speed.
sosic2121
henry wrote:
06 Oct 2019, 19:15
sosic2121 wrote:
06 Oct 2019, 18:37
henry wrote:
06 Oct 2019, 10:40
I'm sorry, it's my fault!
You clearly said "deceleration before breaking", and I misread it.
I should have known better not to question you! :)
As you said, graph hints that Ferrari harvest more than Mercedes before braking zone.
saviour stivala
“I’m saying that after they reach top speed and ‘BEFORE’ they brake they harvest from the ‘K’ ”.
So you are saying that FERRARI drivers can harvest from the ‘K’ without even touching the brake pedal.
Sierra117
saviour stivala wrote:
07 Oct 2019, 03:13
I don't see how that's a problem. Pretty simple to do with just a simple condition in code corresponding to GPS or other location marker of the car's current position.
Nonserviam85
07 Oct 2019, 03:13
During coasting (i.e release the gas pedal before braking), it is perfectly feasible to harvest from the K.
henry
324
Nonserviam85 wrote:
07 Oct 2019, 16:48
07 Oct 2019, 03:13
They don’t need to coast.
When the driver demands max “throttle” the ECU decides what power output that means. There is a choice of 5*. Here’s a set of representative numbers
E-boost 712.5
SSP 682.5 (Self Sustain Plus, ICE + MGU-H + ES)
SS 625 (Self Sustain, ICE + MGU-H)
ICE 562.5 (No ERS)
SH 442.5 (ICE minus MGU-H)
Based on 50% self sustain efficiency of which 45% is ICE and 5% MGU-H.
Other numbers are available.
Control theory studies suggest that these modes are used “bang-bang”, that is they don’t use partial power versions of them.
* I have omitted Honda’s extra harvest mode. And there is another theoretical “extra power” for which I have seen no evidence of implementation.
NL_Fer
82
So at the final part of the straight. Does a driver need to press the brake to engage the K braking or does it brake by itself?
subcritical71
90
henry wrote:
07 Oct 2019, 17:20
and this is why we have the flashing rain light at seemingly random times
If the torque management system on the car decides to go into a fuel-save mode, the rear light will flash for a second to warn any driver behind. The thresholds are configurable but currently set for a car above 95 per cent throttle for more than a second, travelling faster than 180kph, that experiences a torque reduction of 120kW or more.
The warning system has been created because these events are controlled by the electronics rather than by the driver. If the driver decides to back off early then the situation is as it always has been. He has a responsibility to ensure another car is not close behind him. It’s as simple as that. One would normally expect the driver to check that it’s OK to back off. The warning light is there for situations not controlled by the driver.
subcritical71
90
NL_Fer wrote:
07 Oct 2019, 17:47
K harvesting as a result of deliberate braking actuation is always driver controlled. I harvesting as a result of the power strategy is controlled by the control electronics. See previous post about flashing the rain light for just this distinction.
henry wrote:
07 Oct 2019, 17:20
Nonserviam85 wrote:
07 Oct 2019, 16:48
07 Oct 2019, 03:13
When you say MGU-H here by what is it driven in each case?
