Scuderia Ferrari SF90
F1NAC
163
Re: Scuderia Ferrari SF90
This really shows the magnitude of forces acting on tyre and suspension.. Amazing
Good to see you back CrucialX
.poz
43
MtthsMlw wrote:
11 Oct 2019, 16:15
I wonder if the red marked corners are the ones where Vettel uses his ominous third paddle.
actually is a fourth paddle...
gear up gear down friction and the fourth is an hand brake
pimpwerx
Steering wheels have become the demon lovechild of one of those 18-channel RC transmitters, and a Playstation joystick. As someone who mastered both, I still cringe at the idea of having to handle all those inputs while barreling around a circuit at 300kph.
Contact:
Foto Fabrega
Auto motor Und Sport
raymondu999
.poz wrote:
23 Oct 2019, 16:25
handbrake?
失败者找理由,成功者找方法
Mexico
Via AMuS and Motorsport.com
zibby43
613
Morteza wrote:
25 Oct 2019, 01:08
Mexico
https://imgr1.auto-motor-und-sport.de/F ... 639856.jpg
We get some great shots with the rear ends of these cars opened up in Mexico.
.poz
43
raymondu999 wrote:
24 Oct 2019, 21:24
.poz wrote:
23 Oct 2019, 16:25
handbrake?
https://translate.google.it/translate?h ... 4559846%2F
Mexico FP
Via AMuS
Coefficient
Contact:
Dream Theater wrote:
25 Apr 2019, 21:15
C Plinius Secundus wrote:
25 Apr 2019, 15:36
That's not a rear wing, it's an anchor...
I guess that Maranello didn't receive the memo about non linearity between air resistance and speed.
Of course, why they didn't hire you so they could've solved all aero problems months ago...
Come on guys, again with this type of comments that not only aren't adding anything to the discussion, but are also "offensive" towards all the technicians working hard to bring updates on the car.
They must be suffering from 6 degrees of inner Turbulence but, the can find all they need in their minds if the take the time. Or perhaps they're tired. After all, morning comes too early and nighttime falls too late. 🎸
Contact:
On the leclerc car still pitot tubes
Leclerc's car set with full downforce, Vettel on "efficiency setup".
Edited for better images.
In todays low grip conditions both drivers ended up using full downforce.
Sevach wrote:
15 Nov 2019, 23:40
I think they'll stick with it, tyre deg was quite high and they lost a lot in the corners already.
via f1ingenerale.com
