machin wrote: ↑Tue Dec 10, 2019 10:00 pm
We’d have to put in a new data set for the new car, but that’s not a big problem.
You are right, I forgot it.
As soon as possible I will declare the basic data (wheelbase, weight, engine power, cooling flow, inlet/outlet engine flow, ...) so you can add it to VSW and LDVH (if it is ok to provide a demo version of MFlow) can provide a template (similar about all other features to MVRC template).
I was tempted to add a braking model based on cooling flow inside brake ducts, but 99% I will only require a postive pressure integral on an ideal brake cooling duct inlet (as we did for engine cooling in the old KVRC cars).
