What car do u drive and what have u driven so far?
djos
137
Re: What car do u drive and what have u driven so far?
Phil wrote:
Wed Dec 11, 2019 9:41 am
This is good information about the DCT. However, how damaging slow driving is to these transmissions surely also depends on the gear ratio? E.g. a longer first gear will mean the clutch could fully engage at lower speed? Meaning that the slipping would only occur at speeds from 1kmh to 4-5kmh, rather than up to 10-15kmh?
I guess i never really thought about that, but given i do find myself in traffic jams every now and then, driving at walking speeds sometimes, even up hill, is unavoidable in these situations.
Most DCT cars I’ve driven have a very short 1st ratio (including my own).
The impossible often has a kind of integrity which the merely improbable lacks.
535
SmallSoldier wrote:
Tue Dec 10, 2019 10:50 pm
....Actually, In traffic, the DCT will always be better than a manual, since the clutch slip is regulated... Furthermore, most DCT’s have “wet clutches” and won’t burn themselves in that situation...
What is not advisable is to push the car in “normal” Mode, thus is because the clutch pressure in normal/comfort mode is very low and that will induce clutch slip and therefore faster wear of the clutches.
are these clutches friction clutches ? ...or ...
non-torque-multiplying fluid couplings ? ...or ...
contact-load-modulated friction clutches ? (eg hydraulically modulated)
CVTs wore their clutches where owners thought they gave non-wearing creep like a fluid coupling
likewise most of the semi-automatics
Jolle
Jolle
187
Tommy Cookers wrote:
Wed Dec 11, 2019 11:26 am
I think DTC’s normally have multi plate dry friction clutches, like race cars. Except the first generation VW’s, they had wet clutches. A dry clutch is more efficient then a wet one.
SmallSoldier
SmallSoldier
153
Performance oriented cars use DCTs with a multi plate wet clutch configuration... The use of oil with clutches and friction plates is to help dissipate heat... Dry applications are usually used in low torque / performance vehicles
Porsche, BMW Ms, Nissan GTRs for example use wet clutch DCTs
strad
269
The 2020 GT500 is going to have a DCT with a "wet/dry" clutch pack.
It's only "wet" when it start over heating.
Sir Stirling Moss
