General Honda F1 Topic
Wazari
623
Re: General Honda F1 Topic
Sorry I'm not going to answer all your PM's individually but they all seem to have the same common questions so I will try and answer them the best I can.
IHI is not a technical partner any longer and not supplying components for "free" but they are still manufacturing some TC components to Honda's specs.
I don't want to get into this whole Alonso thing. The only thing I do know is that he is not the reason for the McLaren - Honda divorce. If Humpty Dumpty were driving for McLaren instead of Alonso the break up was inevitable.
The new Spec PU really needs different gear ratios in the higher gears to fully exploit its power band. Although the new PU should definitely see a power increase, the big gain should be a more efficient relationship between the ICE and H unit to benefit harvesting and deployment.
-- Honda Soichiro
Viruzpunk
Viruzpunk
Ty Wazari, good to see you :)
Wazari wrote:
07 Feb 2020, 18:31
Nice to see you on the forum again @Wazari san!
I hope you're fine.
Thanks for all the information.
Hopefully RBR / Honda can finally challenge Mercedes and Ferrari . :)
lio007
314
Thank you Wazari!
Good to hear that there will be some improvements!
For me it's a pity, that we haven't seen a fire-up video yet!
Viruzpunk
Viruzpunk
Wazari wrote:
07 Feb 2020, 18:31
Can someone explain this plz. Does that mean we could stretch gears ratio ( for ex using 7th gear longer instead of the 8th as previously done) while maintaining torque and i guess at the end adding top speed ?
Brake Horse Power
Brake Horse Power
Yes, at least make sure the whole width of the powerband is used. So bigger steps in between the 8 gears. Probably you end up adjusting gear ratio in? the diff? to prevent making extremely high top speeds. You just want to be at top speed as quickly as possible.
yener
Brake Horse Power wrote:
08 Feb 2020, 01:19
I agree with you, but what i get is they should deploy more energy in the higher gears. Altough i dont know if you can map the power deployment of the MGU depending on the gear your in. If not, they probably finding more energy to deploy at all gears.
"Life is about passions - Thank you for sharing mine" MSC
ispano6
143
Viruzpunk wrote:
07 Feb 2020, 21:57
Wazari wrote:
07 Feb 2020, 18:31
Tanabe and Yamamoto said the RB15 was low geared. Taller gears will help in better modulation of torque delivery instead of being punchy and peaky, and more fuel efficient at top speeds.
hollus
Last year, the Red Bull needed about 500rpm more, in 8th gear, to reach any given speed compared to the Mercedes and the Ferrari, which had approximately equal 8th gears.
But I am not sure about the rest of the gears.
“More fuel efficient at top speeds” is the same as more power at top speeds in this fuel limited formula, isn’t it? Sounds more acceptable from a marketing point of view, though.
Rivals, not enemies.
Capharol
Capharol
21
hollus wrote:
09 Feb 2020, 10:00
sounds actual silly doesn't it ... 500rpm of the 12krpm they use ... but the higher the rpm the more the engine gets worn and I think it might even affects the fuel consumption
Alexf1
Alexf1
hollus wrote:
09 Feb 2020, 10:00
What would that mean for the RB16 top speed?
Snorked
Snorked
68
We have a fire up 😍
aleshondas
aleshondas
Its smooth as f..k and i like it
lio007
314
Snorked wrote:
09 Feb 2020, 15:27
We have a fire up 😍
Yeah...finally!
This was overdue :-)
hollus
Alexf1 wrote:
09 Feb 2020, 14:59
hollus wrote:
09 Feb 2020, 10:00
In tracks where top speed was 330 km/h probably nothing or close to nothing (well, as someone pointed out, more revs = more wear, but it also means an earlier shift so one needs to look at all the gears there). In tracks where top speed was 350+ with a draft, they had to go to 12500 rpm or higher IIRC, and the engine power drops a lot there, so the top-top speed could have been 2-3 km/h higher in those situations.
That "handicap" only happened in 2-3 tracks, and then only in 2-3 laps. And this only happened because either a) their car was more slippery than they though (win?) and/or b) Honda delivered more power than they predicted (win).
So a tiny hiccup, really.
