Williams FW43
Lotus102
Re: Williams FW43
roadie wrote:
Thu Feb 20, 2020 5:39 pm
MtthsMlw wrote:
Thu Feb 20, 2020 3:10 pm
https://pbs.twimg.com/media/EROX-zaUEAU ... name=large
via @vialibreenrue93
I don't think this really shows why the car appears to be so bulbous in the upper mid section. Is expansion room necessary there to draw air through the radiators/intercooler?
Could just be that they simply put more cooling in this area than other teams do. It's also a cooling efficiency thing - they need more volume to cool as efficiently as Mercedes does, so their sidepods are a similar size to the Merc's but engine cover is a lot bulkier. Even so, this area is still way slimmer than last year. Have a look at these pics (Ignore the highlighted suspension bits, I nicked these photos off the main Williams story).
tomazy
tomazy
206
Re: Williams FW43
dtro
dtro
Re: Williams FW43
Pretty interesting video showcasing Williams improved slow speed stability- almost a second gained in the last sector of Barcelona alone.
humble sabot
27
Re: Williams FW43
That's already been posted, but it's worth noting that that was five races into the season versus day one of testing.
We can probably safely expect a better delta by Spain this year. Question is where that puts them in the mix.
Looks like the nose is the one unchanged part from the FW42.
The goat belly is actually a very nice organic shape, I think it resolves the conflicting demands of having four different flow streams around there - under, over, side, of sidepod, and the more horizontal flow along the side of the airbox/central spine - being almost circular in cross section air is never going along the 'wrong' vector.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Re: Williams FW43
Via AMuS
Lotus102
Re: Williams FW43
Does anyone know if the gearbox casing is still metal or have Williams finally gone carbon?
ScrewCaptain27
577
Re: Williams FW43
Lotus102 wrote:
Fri Feb 21, 2020 12:26 pm
It’s clearly still all-metal.
- Serj Tankian
Lotus102
Re: Williams FW43
ScrewCaptain27 wrote:
Fri Feb 21, 2020 12:33 pm
So is that the gearbox casing that you can see on the cover-off photo above? There's so much packed in there these days I wasn't sure what I was looking at
ScrewCaptain27
577
Re: Williams FW43
Lotus102 wrote:
Fri Feb 21, 2020 1:22 pm
Yes
- Serj Tankian
dtro
dtro
Re: Williams FW43
humble sabot wrote:
Fri Feb 21, 2020 7:15 am
Of course it's too early to tell, but in comparison to last year the car's body language looks a lot more predictable, to say nothing of them being there with a car. If the problems from last years cars can be either diminished or eradicated (unpredictable cornering) they could find themselves in the mix with Haas/Alfa.
Lotus102
Re: Williams FW43
So, without wishing to pour cold water on what was in most respects a pretty positive test for Williams, should we be worried about the engine issues on Thursday and Friday? Was it purely a Merc related issue or might there be something in the installation that the PU doesn’t like? Remembering all the cooling problems on the FW41 with some trepidation.
Lotus102
Re: Williams FW43
Seems like an awful lot of rake on the FW43 this morning (in more ways than one)
Lotus102
Re: Williams FW43
More correlation tests this morning, by the looks of things. Change of front wing already on Latifi’s car
Re: Williams FW43
Different flaps configuration with cuts and curvature on the Williams.
NtsParadize
NtsParadize
Re: Williams FW43
