DAS Dual Axis Steering...Legality??
Mattchu
60
Re: DAS Dual Axis Steering...Legality??
Clutching at straws! But it`s moveable aero...That`s for sprung weight if I`m not mistaken and the wheel doesn`t come under this.
Mercedes have made what has become a pretty sterile F1 into something that every sports paper is talking about, even if they don`t use it, the good press its given F1 is worth its weight in gold...
What if another team shows up with it in a few days :?
AJI
AJI
27
erikejw wrote:
24 Feb 2020, 22:52
"10.4.5 Power steering is allowed but such system may not carry out any function other than reduce the physical effort required to steer the car and must allow the steering to continue to function when all hydraulic and/or electric power is shut down."
Since DAS is part of the steering Mercedes needs to show that their drivers can do the toe in and toe out as efficient without the help of power steering, otherwise it should be deemed a safety hazard and forbidden.
Imagine a car with power steering and a malfunction( Senna comes to mind), then uncapable to operate.
DAS might not even use use power steering, hydraulics. Then all of the above is forfeit.
There have been some pretty wacky ways described for the possible operation of DAS, but if we 'Ockham's razor' this, it wouldn't be that difficult to just manually move the rack fore and aft
Anony Mous Engineerd
This is clearly illegal, and surprised in 47 posts, no one quoted this:
10.4 Steering :
10.4.1 Any steering system which permits the re-alignment of more than two wheels is not
permitted
If that toe has 2 different specs due to the moving steering wheel, than fails the above reg.
It was legal for testing, not a race.
DAS is a red hearing to hide all the new aero in the car, and the team at MB headquarters is laughing their collective asses off at the attention and squabbling this has caused.
Mark my words...
AJI
AJI
27
Anony Mous Engineerd wrote:
25 Feb 2020, 01:35
10.4 Steering :
permitted
It's not re-aligning 'more than two wheels'
Well,,, when you put that in bold, it's kinda obvious... The Parc Ferme thing still has legs, and I am sticking with my idea that the DAS is all for SHOW... they are hiding some other Aero trick...
If the DAS moves the steering rack, how easy would it be to use it as an F duct? In one position it covers a duct and uncovers it in another position.
AJI
AJI
27
25 Feb 2020, 02:43
Why Parc Ferme? They change tons of stuff all the time while in 'Parc Ferme'.
AJI
AJI
27
godlameroso wrote:
25 Feb 2020, 03:01
Surely that would be considered moveable aero? Not to say they're not doing it, but that car would have scrutineers all over it and I dare say every other team has lodged a protest by now.
saviour stivala
saviour stivala
53
Sieper wrote:
24 Feb 2020, 14:33
What I don't understand is any moveable aero is forbidden.
With toe-in your wheels have a larger frontal aero surface then with toe neutral. So by moving the wheels to toe-neutral you are having less of an aero impact and as such it is moveable aero. They way how you achieve it does not really matter anymore. The fact that you have a way of controlling it to your suit is enough to call this moveable.
Then, to make matters worse, there is the way you control it, yes you use the steering wheel, but not to steer, just to actively control the aero frontal impact of the front wheels. When pulling the steer toward you and when pushing it away you are not steering at all, you are moving in a straight line. The only purpose is to change toe-in and with that frontal aero surface is reduced.
Contrary to what have been said the steering wheel is not pushed or pulled by the driver, the steering wheel movement (up or down/towards or away from the driver) is actuated by the driver via a push button.
Dr. Acula
Dr. Acula
46
saviour stivala wrote:
25 Feb 2020, 13:02
I highly doubt that.
10.2.2 Any powered device which is capable of altering the configuration or affecting the performance of any part of any suspension system is forbidden.
Also, if the driver can activate the adjustment with a button, then why they have designed it that the steering wheel is moving at all? What is far more likely is that the driver has to press a button to simply unlock the mechanism.
SiLo
139
It's hydraulic but the power is supplied by the driver, and multiplied by the system. Just like a braking system.
Felipe Baby!
Wynters
Wynters
Are people seriously arguing that it's 'movable aero'?
Of course it's moveable aero. But so is every other steering wheel. And the brake/accelerator pedals. And the driver's helmet. And their hands.That's why the rules don't specifically rule out the steering wheel being used to make aero adjustments.
Perhaps Williams should just weld George Russel into the car (and his pedals and steering wheel) and then lodge a protest against every other team the second after the lights go green and the rest of the field pulls away. It's probably the only way they are going to get points this season. I'm sure all the posters complaining about Merc's 'movable aero' will just as vocally support RBR at al and Ferrari et al being disqualified?
2007 - Beats 2005 & 2006 WDC Alonso. 1-0
2008-09 - Beats Kovalainen. 2-0
2010-12 - Beats 2009 WDC Button. 2-1
2013-16 - Beats 2016 WDC Rosberg. 3-1
2017-21 - Beats Bottas. 5-0
2022-24 - Loses to Russell. 1-2 (but outscores him)
2025-?? - Leclerc. TBC
Just the car???
vogonvader
vogonvader
hollus wrote:
24 Feb 2020, 18:20
In any case, Mercedes can "legalize" its car in extremely short notice, just by immobilizing the system.
Yeah but without DAS's gains the possible compromises they've made in structure or the additional weight of the system might even lose them some time, wouldn't it?
Brian.G
Brian.G
334
This thread reminded me of a prototype system I developed for a company a good while ago - and one which by its design I always assumed was illegal, or not mean to be ever found.
The design in theory was pretty simple - the steering arms and rack were behind the front wheels. Under braking, the steering rods grew in length by means of a second brake master cylinder - thus keeping toe in check even with wishbone bushing compliance taken into account due to brake forces.
Brian,
If you think you cant, you wont, If you think you can, you will
izzy
izzy
rohan wrote:
25 Feb 2020, 19:41
Am surprised that the FIA are leaning towards DAS being legal - in my view (as someone who has been interviewed as a technical expert in Autosport) it's clearly against the rules, but of course only the FIA's view matters.
it's supposed to be against the rules, but they accidentally wrote it so it only applies if the steering wheel is fixed #-o
the steering can't remain immobile in relation to the sprung part of the car, so the aero rule doesn't apply either
this is why they had to write a new rule for next year. FIA are actually doing it right :shock:
