2009 design concepts
WhiteBlue
124
Re: 2009 design concepts
So far drivers have commented, that the new front wing is much more stable. So it looks like one of the objectives could be reached.
I must say that the clean look of the cars is very appealing. We will get used to the new proportion of wings and I'm quite eager to see what the first technical cooperation of F1 top teams (OWG) has achieved.
It can't be that bad after all the consultation and study.
autolover
so ugly,especially his rear wing,which makes me reminding of 90s!
Yes,we can
humble sabot
delsando wrote:
Scotracer wrote:
Metar wrote:I have a purely hypothetical question: Would it be legal to move the air-intake of the engine to the location of Ferrari's Frankenradiator?
I don't believe so but it wouldn't be advantageous. The air flow in that region doesn't have good characteristics (Reynolds number and pressure) compared to the air intake above the driver. Also, the fluid dynamics of the air intake would have to divert the flow from that position on the right around to the top of the engine, inducing more losses.
Either way, the rollover structure has to remain where it is so the air intake wouldn't reduce this height, by removing it.
So, hypothetically yes I believe they could do it, but it wouldn't be a good idea.
To shed more light on this,
refer Manchilds intuitive idea of airbox
viewtopic.php?f=6&t=5135&start=0&st=0&s ... irbox+idea
I think, the fact that the rollover structure and engine intake are allowed to be integrated (wasn't always the case) actually allows for pretty much a best case scenario. It allows the airflow aft and above the driver's head to be fair. I don't think height there is an issue, but i think that mostly depends on the relative speed of air going into the airbox I think.
I see manchild's idea to be very draggy. It isn't used anymore in lemans prototypes and the like anymore. Even if you do a nice job, that funny curvy loop, just has too much surface area. See the latest Audi and Acura LMPs for instance
Image and
It would be nice if there was another solution proposed in place of the peripheral-vision-robbing side head restraints.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Norseman
Norseman
Wow! This has turned into a very informative thread! I've been so busy working on this project that I haven't had the time to come back and check on it for quite a while. I was unable to bring up any of Smirkoff's images that he shared ( http://img233.imageshack.us/my.php?imag ... ualxh4.jpg ) - can someone share them here by another means? I'd like to check it out and compare it to what we've put together thus far. Thanks guys, F1Technical really is a great forum!
Agerasia
Agerasia
I've just studied the McLaren main front wing flaps against the Ferrari after reading the article posted on this site. They both fold back and down at the inner edge nearest to the neutral part of the wing. Is this not going to cause airflow to be slower over the top part of the neutral section?
"badically pressuring rosnerg " Ringo 05/10/2014
megz
A poor MS paint mock up - but the idea should be there, a low fat wing profiled nose - would there be any advantage in running such a nose at any kind of angle?
three views to sort of show what I mean.
mariof1
mariof1
Unfortunately the cockpit/nose width must decrease as shown in this drawing (red area is the minimum dimension).
mx_tifoso
How is the heat that was once dealed with by using chimneys and gills taken care of now that those bodywork openings are banned? I recall reading about changes in the design of the cooling system, but nothing indepth. Does anyone have any info on that? Exactly what were those changes?
ISLAMATRON
mx_tifosi wrote:How is the heat that was once dealed with by using chimneys and gills taken care of now that those bodywork openings are banned? I recall reading about changes in the design of the cooling system, but nothing indepth. Does anyone have any info on that? Exactly what were those changes?
They will go back to the old style of exhausting the cooling air out of the back of the car... check these picks.
http://www.f1today.nl/foto/5174/
http://www.gurneyflap.com/Resources/djm0912ja02.jpg
mx_tifoso
Alright, thanks. On the Toyota, is it the vent under the exhaust outlet?
ISLAMATRON
not fully understanding the wording of your question... both the toyo & the F60 have oversized holes for the engine exhaust pipes to also allow for "cooling" air to also escape but then they also have a main exhaust for cooling air out the back of the car behind the rear axle. There was an excellant pic of that for the F60 but I cant find it at the moment, I am still waiting to see the rear shot of the MP4/24.
EDIT: check the F60 360
http://ferrari09-http.weebo.it/Ferrari_ ... ng/vt.html
Conceptual
Conceptual
With all of the sidepod inlets dumping directly out the back of the car instead of out chimneys/gills, will that allow for more of a center downwash at the rear of the car? Or at least more so than 2008?
