2020 car comparison thread
Re: 2020 car comparison thread
Heave spring comparison between Mercedes and Ferrari
via @JunaidSamodien_
Rake comparison
MtthsMlw wrote:
Thu Feb 27, 2020 4:34 pm
https://pbs.twimg.com/media/ERysNjCXYAA ... name=large
The diffusers are the same height so the rake of each, at that point, gave the same result.
Mandrake
Mandrake
19
Gotta say that Mercedes in that shot does not look like a lot less rake. I mean the car is longer than the others that makes it look a little less, but Diffusor height looks rather similar.
kimetic
kimetic
Mandrake wrote:
Fri Feb 28, 2020 9:18 pm
Yes the difference is pretty small, something like 1.4 degrees versus 1.9. Hopefully AMUS will publish the rakes and wheelbases.
Pyrone89
Mercedes is more tightly packaged, has cleaner airflow because the RB16 has the suspension arm in the middle of the airflow, has more detailed endplates and runs both the endplates and diffuser bodywork closer to the tyre than RB. Also the RB cooling exit is bigger and the rear bodywork is not so much sloped downwards at the diffuser as the Mercedes.
Those are areas where Mercedes looks better.
Best WDC-drivers in F1 history:
Schumacher, Senna, Fangio
Driving a dominant car in the most dominant team ever, helped by favorable rule changes, against subtop teammates does not make you the GOAT (but still superb). It just helps you inflate/skew your stats.
izzy
70
These are the averages of the race sim 2nd Stint C2 times from @f1debrief. He doesn't label George's a race sim but it looks like it. It could be a first stint, would help! Romain's is a shorter stint than the others.
Russell (C2) 24.46
Daniil Kvyat #AT01 23.35
Sergio Perez #RP20 23.12
Carlos Sainz #MCL35 23.10
Romain Grosjean #VF20 22.42
Charles Leclerc #SF1000 21.88
So it looks like Williams are still a bit of a way off the others :( , and Ferrari are over 1s clear of the midfield including McLaren. I don't see these stints for the others, so far
f1316
f1316
132
Pyrone89 wrote:
Sat Feb 29, 2020 1:35 am
Red Bull has a lot less rear wing.
f1rules
f1rules
382
copypoint running almost inverted rake with drs open, they must be running very soft rear ;-)
Maybe they are not running any rake?? well...... no
but without drs
not even rb who was the master of this in the past
OO7
OO7
128
