Block in developments to save costs
Pyrone89
Re: Block in developments to save costs
Blackout wrote:
28 Mar 2020, 11:38
Pyrone89 wrote:
27 Mar 2020, 01:11
Would this prevent others from getting DAS and variable Ackermann, as these are housed in and on the monocoque
Probably. Same chassis, same rules, same mechanical parts => same steering IMO
According to Tost, "The chassis will be homologated. The mechanical parts too, such as the suspensions. The only thing that can be improved is the aerodynamics. That's the front wing, rear wing, body, sidepods, floor, diffuser and deflectors."
Is the cooling still part of the aerodynamics and can be changed in 2021?
That would make Mercedes the 2020 and 2021 champions. Seeing how no-one will be able to get DAS and Ackerman in time, or catch up with the suspension magic they have. I cannot understand why Ferrari, RBR and AT would agree with this. If it is about costs they might as well stop competing, saves even more money than accepting you are certain to not be the champion.
izzy
Pyrone89 wrote:
28 Mar 2020, 20:53
DAS is pretty marginal and they all have as much ackerman as they want, if Mercedes really are using DAS for the steering angles then it's just the last tiny bit of refining
it'll be much more important how much traction they've got and kerb riding and aero balance during braking and tyre use and stuff like that. Meanwhile Honda will be better again and Ferrari busy catching back up with their power, so the cars will be more even than ever and it'll be the strategy and setup and driving that'll decide the championships, stay cool! :)
Big Tea
Pyrone89 wrote:
28 Mar 2020, 20:53
Blackout wrote:
28 Mar 2020, 11:38
Pyrone89 wrote:
27 Mar 2020, 01:11
As none of the teams presented a car to stewards yet, we don't know what they have.
saviour stivala
51
Big Tea wrote:
28 Mar 2020, 22:09
Pyrone89 wrote:
28 Mar 2020, 20:53
Blackout wrote:
28 Mar 2020, 11:38
And neither what they will have (changed/modified) when and if racing starts and they presents their cars.
RZS10
359
https://www.motorsport.com/f1/news/merc ... 1/4775355/
DAS banned for 2021 ... depending on whether there will be any racing in 2020 it might end up never being used
Jambier
New rules may now be postponed to 2023
Also, work on 2022 (or 2023) cars is now prohibited , I don't know what that means
henry
324
RZS10 wrote:
31 Mar 2020, 15:15
That’s a shame. DAS, and it’s underlying steering control of individual wheels, was an interesting topic of conversation. One we could all get our heads round. It would have been interesting to continue to speculate on its implementation and see its use in races. The new regulation that controls it seems bullet proof.
Maybe Mercedes, or Ferrari, will be encouraged to reveal what they were up to.
Pyrone89
Now the discussion is shifting to Mercedes’ gearbox in which they apparently only need 4 bolts vs the 6 of others, making them have an advantage. Ferrari and Red Bull are appearing to be against component freezes to prevent locking in the Mercedes advantage (and rightly so if you ask me).
No doubt that once Ferrari and RedBull think they've got all of Mercedes's tricks on their own car, they'll be all for freezes at that point... :wink:
izzy
henry wrote:
31 Mar 2020, 17:13
RZS10 wrote:
31 Mar 2020, 15:15
Yes i'm really hoping to see it in action in some races, it's something visual and just interesting
Pyrone89
Tokens are coming up again as a real possibility. Have they learned nothing from the past that all a token system does is greatly benefit the leading team/car? They are already ahead so in normal cases would need to spend less tokens than the teams that first have to change a lot of parts to catch up.
It is like they don't want F1 to get less predictable.
Big Tea
Pyrone89 wrote:
07 Apr 2020, 23:20
https://twitter.com/AlbertFabrega/statu ... 59552?s=20
I think if tokens are used again it has to have some sort of handycap weighting. For instance, all teams get 100 points worth at year start, but each podium place decreases the points by a small amount. Teams not scoring keep the 100 until they are passing the lead teams, then they start dropping and another team benefits.
This however would be very difficult to get right, especially as teams om both ends of the grid have the same engine.
Not ideal, but as we saw, a straight limit just keeps the status quo at best, or stretches the spread
sprint car76
The new mantra - keep screwing with it until you ruin it. See nascar.
ENGINE TUNER
25
Pyrone89 wrote:
07 Apr 2020, 23:20
Again, you are wrong, the previous token system held Merc back more than any of the other PU manufactures. The tokens stop alot of small improvements and force larger improvements, so in fact favor those who are further behind. Look at the huge jump in engine performance Ferrari had from 14 to 15. Also the tokens gave so much scope for improvement/change that Honda was able to fully switch their PU concept from 16 to 17. The tokens in reality held nobody back(not 1 manufacturer used all their tokens), but held Mercs improvement back more than the others.
Furthermore, UNLIMITED reliability changes were allowed, and yet Renault and Honda were still failing left, right and center. Do not confuse Renault and Honda's incompetence for failure on the part of the token system.
What makes F1 predictable is lining up the grid in order based on qually, tokens would have no change on that.
ispano6
143
ENGINE TUNER wrote:
08 Apr 2020, 21:40
Pyrone89 wrote:
07 Apr 2020, 23:20
Just salary cap the drivers at a few million and the rest of the money can go back to development.
