Haas VF-20
Haas VF-20
This is the Haas VF-20 offical car thread.
Please discuss ONLY technical items of this car, and refrain from speculation.
Livery Talk also belongs in the Team Thread. viewtopic.php?f=15&t=28680
Re: Haas VF-20 Speculation Thread
Via @AlbertFabrega
Via @AlessandroSala1
zibby43
zibby43
440
Re: Haas VF-20
via Albert Fabrega
SmallSoldier
SmallSoldier
194
Re: Haas VF-20
3 boomerangs and a lot of vortex generators on the Haas... Taking the complexity cup on the first day?
@NicolasF1i
Re: Haas VF-20
NtsParadize
NtsParadize
Re: Haas VF-20
SF90 clone?
Re: Haas VF-20
Via AMuS
Re: Haas VF-20
Via AMuS
Re: Haas VF-20
Via @Butch_on_Racing
Re: Haas VF-20
Those little actuators seem to be LVDTs... :idea:
I can see the wires connected. They are measureming suspension movements here.
Not driving a Mercedes? Work harder!
Re: Haas VF-20
Tue Apr 21, 2020 8:54 pm
That has been done for many years in this sort of way.
kalinka
kalinka
Re: Haas VF-20
What are those little black boxes at the end of the pushrods secured with two screws? One cable goes to the end of the pushrod, but seems there are no other connection, just some kind of antenna-like protrusion at the other end...looks like some kind of wireless transponder but what should it report/measure?
Re: Haas VF-20
kalinka wrote:
Mon May 18, 2020 7:06 am
Strain gauge to measure force on the pushrod (and thus downforce / wheel loads), perhaps?
kalinka
kalinka
Re: Haas VF-20
Yeah, makes sense. On the other picture from different angle it can be actually seen that it's not wireless, the cable on the other end goes into a hole. The usual F1 "tricks your eyes" effect :D
pierrre
32
Re: Haas VF-20
Just_a_fan wrote:
Mon May 18, 2020 8:49 am
interesting that, pre-suspended(suspension) force sensor data collection to be calibrated with post-suspended(suspension) data collection, must be in there somewhere..even more interesting if they had laser sensors below the suspension uprights targeted at road surface to measure tyre compression and rebound depth and calibrate frequencies between all that to get an improved set up...maybe tyre pressure sensor is a simpler solution, probably less accurate
facebook @speedphysics
youtube/c/speedphysics
