[ 2020 ] Mclaren F1 Team - Renault
pazazamadaz
pazazamadaz
Re: [ 2020 ] Mclaren F1 Team - Renault
M840TR wrote:
28 Jul 2020, 15:10
pazazamadaz wrote:
28 Jul 2020, 10:23
"From 2021, Gulf will become the preferred lubricant supplier to McLaren Automotive, with all cars to be filled with Gulf Oil and fuel optimised for high performance engines"
That answers that question, then.
This is for Mclaren Automotive, not the F1 arm. Up until now they had a deal with Exxon Mobil.
Ohh yeah Automotive not F1. I completely missed that 😳
So they will probably stick with the same lubricant as Merc if not fuel as well.
Jolle
Jolle
133
pazazamadaz wrote:
28 Jul 2020, 15:18
M840TR wrote:
28 Jul 2020, 15:10
pazazamadaz wrote:
28 Jul 2020, 10:23
I think they learned their lesson with trying to outsmart the works team supplier. The thought was that with Petrobas they would by dyno time at Renault to develop their own mix. Not the most efficient way to spend your money.
djos wrote:
28 Jul 2020, 13:16
pazazamadaz wrote:
28 Jul 2020, 10:23
Hopefully they will still be using the same oil as Mercedes in the PU so they don’t suffer in the performance department.
It isn't a hope. it is in the rules. From https://www.fia.com/sites/default/files ... -10-31.pdf
"7) No manufacturer may homologate more than two specifications of fuel and two specifications
of engine oil from their chosen supplier during a Championship season. If fuels and engine oils
from an alternative supplier are preferred by a customer team two additional specifications of
engine oil and fuel may be homologated per customer team. A change of supplier is possible
in-season but this change will be considered as a change of specification.
8) The homologation will be valid for a maximum of one Championship season only, starting on
the date of approval by the FIA and ending on the start of the first Competition of the
following Championship season.
9) Each manufacturer shall submit an homologation dossier for each team it intends to supply.
There may only be one homologation dossier per team. With the exception of Power Unit
wirings, and fuel specification and engine oil specification if an alternative supplier is preferred
by the customer team, the dossier for each team supplied by a manufacturer must be identical
at any given time.
All power units supplied by a single manufacturer must also be operated in the same way, they
must therefore be :
i) Identical according to the dossier for each team, and ;
Unless a team informs the FIA Technical Department that they have declined any of the following, they must be :
ii) Run with identical software for PU control and must be capable of being operated in precisely the same way.
iii) Run with identical specifications of engine oil and fuel, unless an alternative supplier is
preferred by a customer team (see paragraph 7) above)."
djos
115
You’ve ignored the bits saying a customer team can also have its preferred suppliers oil and fuel homolagated.
"In downforce we trust"
Lucky
Lucky
157
bauc
35
*** EDIT**
@LUCKY - beat me to it :mrgreen: =D>
Another day, another sponsor
https://www.mclaren.com/racing/partners ... ip-iqoniq/
genarro
genarro
Zak is on fire \:D/ \:D/ \:D/ \:D/
djos wrote:
29 Jul 2020, 04:54
No, I did not. It is there. The question from prior entries was if they can get the secret sauces that Merc uses. Not sure what point you're trying to make.
Ground Effect
Ground Effect
diffuser wrote:
29 Jul 2020, 13:48
djos wrote:
29 Jul 2020, 04:54
I think his earlier statement was more in line with hoping McLaren decide to go the route of using same fuels and lubricants used by Mercedes, just like what RP and Williams do and not opt for developing their own mix with Gulf. I don’t think @djos was worried that McLaren wouldn’t have access to same products. It’s been clarified for a while now in the rules that any team using a different fuel/lubricant from their PU supplier chose to do so.
djos
115
diffuser wrote:
29 Jul 2020, 13:48
djos wrote:
29 Jul 2020, 04:54
You quoted my post and I did not raise that issue, I only commented that I hoped they will stick with Mercedes oil and fuel and not use gulf products in the Mercedes PU despite the gulf sponsorship.
djos
115
Ground Effect wrote:
29 Jul 2020, 14:27
diffuser wrote:
29 Jul 2020, 13:48
djos wrote:
29 Jul 2020, 04:54
Yep, that was my point.
Lucky
Lucky
157
Lucky
Lucky
157
haza
haza
At Zaks rate the cars gonna have no more space for sponsor/logos
