Racing Point RP20
Ozan
Ozan
Re: Racing Point RP20
amazing photo of how side floor is feeding the diffuser
tomazy
tomazy
223
This feeding is accualy undesirable. All the slots in the floor in that area are there to minimase this effect. By spilling the air from the top of the floor (high pressure) to the bottom of the floor (low pressure) there is a smaller diffirance in pressures and so less downforce. The changes to the regulations for 2021 are there specificaly to make this feeding effect greater.
trinidefender
trinidefender
318
As a McLaren fan I would like to extend my condolences. Checo really deserved that podium and while it definitely helps my team it isn't great to see a drive like that end the way it did.
From a fan of one team that knows the heartbreak of engine failures to another.
As far as components used, does he have to take any penalties?
SiLo
139
Ozan wrote:
29 Nov 2020, 21:12
http://www.imgim.com/eoawggowmaeddrt.jpg
Can you repost this? It's not loading for me, I just get a server error.
Felipe Baby!
jh199
32
I can't see the photo of the side floor sealing the diffuser linked above but here is a Reddit post with a gif showing the same thing.
https://www.reddit.com/r/F1Technical/co ... _diffuser/
tomazy wrote:
29 Nov 2020, 21:30
The flow is kept on top of the floor up until it passes the rear most set of VGs, it then turns under the floor and goes along the inside face of the tyre. Getting a vortex to run around like that would entrain the tyre squirt and thus aid the diffuser massively. This is a good thing.
The 2021 changes will hamper tyre squirt control and thus reduce diffuser effectiveness. That's one reason the diffuser vanes have been reduced in vertical size - it limits how the teams deal with the tyre squirt.
Ozan
Ozan
jh199
32
pierrre
pierrre
56
racing point floor
SmallSoldier
SmallSoldier
486
pierrre wrote:racing point floor
Those are great pics! Thanks for sharing... It’s not often that we get to see this side of the cars :)
Stu
Interesting! We all concentrate on the externally viewable portion of the ‘control structure’ in front of the side pods in terms of how it controls airflow around the side of the car, these pictures show how it also effectively extends the floor right up towards the front tyres.
Previously I had considered that the incoming 2022 rules were to increase the use of the floor for downforce, having seen those shots I would now say that they are more about controlling how you use the floor to control downforce.
jjn9128
779
Stu wrote:
01 Dec 2020, 08:52
The 2022 rules have never been about increasing underbody downforce, just making it towards the centre of the floor rather than at the extremes.
#aerogandalf
Fonsee
Fonsee
Look at the helmet. Smoke out of the monocoque?!
Is there a f-duct? :wtf:
jh199 wrote:
30 Nov 2020, 20:39
hollus
So that's what the floor of the W10 was like!
In the pictures it looks like the diffuser starts as a sharp kink of 60 degrees or even more. Is this possible? That abrupt? I guess they are desperate to make the most of a very limited regulation box.
TANSTAAFL
jjn9128
779
hollus wrote:
02 Dec 2020, 13:58
There's quite a lot of foreshortening on that image. Definitely need to make the most of the box but don't want to stall the diffuser (at most ride heights).
#aerogandalf
