2021 Mclaren F1 Team
Team: Image McLaren F1 Team
Base: Image McLaren Technology Centre Woking, Surrey, United Kingdom
Team principal(s): Zak Brown (CEO), Andreas Seidl (TP)
Technical director(s): James Key (TD), Andrea Stella (RD)
Race drivers:
3 Image Daniel Ricciardo
4 Image Lando Norris
Chassis: MCL35M
Engine: Mercedes V6 Turbo
This thread is to discuss the 2021 Mclaren F1 TEAM
McFAN
McFAN
Re: 2021 Mclaren F1 Team
Happy new year folks !!
_cerber1
218
_cerber1
218
McFAN
McFAN
Ricciardo will spend time at the factory, as well as capitalising on electronic communication given the ongoing COVID-19 pandemic.
“We have a clear plan in place of how to integrate him in the best possible way,” said Seidl. “The main focus is on integration on the technical side, on the racing side. But in parallel to that we have as a programme in place to integrate him as a team member on the communication side, the marketing side and the business side. That will start flat out from the beginning of January.
https://the-race.com/formula-1/mclarens ... m-veteran/
bauc
32
https://www.motorsport.com/f1/news/mcla ... n=widget-1
Lando is positive to covid 19 but feeling fine
Big Tea
90
bauc wrote:
Tue Jan 05, 2021 9:41 pm
Probably better to 'get it over with' as long as he is not ill. There seems to be lots of evidence you can not get it again, so should be oK all year.
It's Just Flu... Nothing to Worry about...
_cerber1
218
Pat Fry believes that McLaren will be able to gain an advantage when changing the power plant.
Through a translator: https://f1news.autoroad.cz/novinky/1003 ... cekava-fry
the EDGE
the EDGE
65
An interesting piece on AMuS https://www.auto-motor-und-sport.de/for ... nterboden/ discussing whether the new floor rules for 2021 will disadvantage the high or low rake philosophy more
It also suggests McLarens move to a Mercedes style nose indicates they will run less rake this year
genarro
genarro
the EDGE wrote:
Wed Jan 06, 2021 10:40 am
I have read somewhere that the high rake concept isnt as developement friendly as the low rake. just look at RB for all these years and still cant beat Merc.
The lower rake concept is the way to go
genarro wrote:
Thu Jan 07, 2021 9:52 am
That statement is so misleading it isn't funny. You make it sounds like the 2 cars are identical, the only difference is the rake.
Fact is Merc have had issues getting high rake to work, their cars have increased rake over the last few years. Think they were up to 1.7- 1.8 this year where RBR are at 2.3. Don't forget Merc's car is longer than the RBR, it need less rake to get to the same height. Also you talk about rake like rake is always on. Once a car hit 150KPH, rake is gone.
If teams have lower rake this year, including McLaren, it will be cause they have problems sealing the floor with the reg changes. I presume they will not fix they're mechanical grip issue out of slow corners this year, its been there in a varying degree since atleast 2014. Lower rake will make them even slower out of corners.
You might see them come out with lower rake and slowly increase it as they figure out the new regs.
Remember you need more rear wing to make up for less rake. More rear wing create more drag at high speed.
From https://en.wikipedia.org/wiki/Drag_(phy ... (60%20kW).
Note that the power needed to push an object through a fluid increases as the cube of the velocity. A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome aerodynamic drag, but that same car at 100 mph (160 km/h) requires 80 horsepower (60 kW).[17] With a doubling of speed the drag (force) quadruples per the formula. Exerting 4 times the force over a fixed distance produces 4 times as much work. At twice the speed the work (resulting in displacement over a fixed distance) is done twice as fast. Since power is the rate of doing work, 4 times the work done in half the time requires 8 times the power.
Rake difference will likely disappear next year when the rear wings are are far smaller.
shotzski
Permission to post this video link in this thread. This is a documentary of Ron Dennis. Please enjoy
McFAN
McFAN
