Mercedes W12
pursue_one's
97
Re: Mercedes W12
Both Mercedes drivers opted for the lighter option, including no T-Wing.
Bottas' rear wing has a gurney flap.
dans79
267
Re: Mercedes W12
zibby43 wrote:
16 Jul 2021, 21:21
Here's a nice view of the new, split pontoon/side pod deflectors (along with the new floor furniture and barge board tweaks):
https://pbs.twimg.com/media/E6b6pmWWEAI ... ame=medium
As another poster pointed out, a similar update was brought on the W10 around Germany, I think?
It will be interesting to see how much more time they can squeezer out of this upgrade, when they actually have time to try and optimize the set-up. With only 60 minutes to test out the upgrades, and get the car ready for qualifying, they can't possibly have gotten everything out of it.
197 104 103 7
Zynerji
110
Re: Mercedes W12
So, has the sky officially stopped falling? 😏
zibby43
613
Re: Mercedes W12
dans79 wrote:
16 Jul 2021, 22:33
zibby43 wrote:
16 Jul 2021, 21:21
Completely agree. It also may unlock a better development path for whatever bits they have left, now that they know this new package is much more efficient (but still provides the stability they need).
It was very encouraging to see both drivers opt for the smallest RWs of the season, with no t-wings.
Starkblood80
Re: Mercedes W12
Zynerji wrote:
16 Jul 2021, 23:29
Can’t help think it’s a false dawn
zibby43
613
Re: Mercedes W12
Starkblood80 wrote:
17 Jul 2021, 07:20
Zynerji wrote:
16 Jul 2021, 23:29
Why is that?
Starkblood80
Re: Mercedes W12
zibby43 wrote:
17 Jul 2021, 07:46
Starkblood80 wrote:
17 Jul 2021, 07:20
Zynerji wrote:
16 Jul 2021, 23:29
Why is that?
Because unless there’s more going on than we’ve seen, I can’t see how such a modest update has improved the car to the point it’s on par with the red bull
djones
Re: Mercedes W12
Maybe if the car was performing ok a 'small' update won't do much.
But it's possible there was a fault with the aero and this is more of a fix than a small update.
mkay
16
Re: Mercedes W12
Starkblood80 wrote:
17 Jul 2021, 10:16
zibby43 wrote:
17 Jul 2021, 07:46
Starkblood80 wrote:
17 Jul 2021, 07:20
Why is that?
Agree. It’s highly likely track conditions (much cooler track for qualifying) and traxk layout (front-limited) just went Merc’s way, rather than this upgrade being a magic bullet.
dans79
267
Re: Mercedes W12
djones wrote:
17 Jul 2021, 11:11
This is exactly what it was!
197 104 103 7
pursue_one's
97
Re: Mercedes W12
Craig Scarborough@ScarbsTech
Trimmed rear wing flap to reduce drag on the straights for Merc
pursue_one's
97
Re: Mercedes W12
Lewis using a right-hand preset toggle for Turn 16
What's this?
https://twitter.com/AnnotatedWA/status/ ... 9587670018
marcel171281
26
Re: Mercedes W12
pursue_one's wrote:
18 Jul 2021, 01:22
What's this?
https://pbs.twimg.com/media/E6e86sTVgAMWSkr?format=jpg
They probably can preset multiple setting behing that one button. So in one press go to different engine braking, diff entry settings, brake balance etc, just setup for a single corner of section or corners.
atanatizante
107
Re: Mercedes W12
Is it me or we didn`t look at the big picture:
It`s not the high rake we`ve seen at RB but due to their longer wheelbase they don`t need that angle to achieve the same volume under the diffuser
It`ll be nice to see a side-by-side comparison between the two teams high rakes and these updates must correlate with the changed rake, don`t they?
Jesus
Spacepace
Re: Mercedes W12
atanatizante wrote:
18 Jul 2021, 19:53
https://postimages.org/
Right. Wasn't it Scarbs saying that Merc has lost more due to the regulation mandate on rear brake winglets. Not having that extended lower hurts Mercedes but doesn't change much on high rake due to the diffuser angled closer to them. I know it's been discussed already but thought it should be hammered home
Edit found it. Around 3:30.
