Are you sure?
I thought the air coming from the back is the 'switch' the main air that stalls the FW is through the hole at the front.
The is a good chance its still two different systems of course.
"There was then a lengthy discussion in the TWG at the beginning of last year about that, to make sure everyone was clear about it. It seems a couple of teams went away from that meeting with the impression that F-ducts were banned in general. Whatever an F-duct is. But they are not.
What it appears some teams are doing is that when the DRS is operated, it will allow air to pass into a duct and do other things.
That is all I can say – you will probably have a pretty good idea of what it might be doing, and other teams will as well. But it is completely passive. There are no moving parts in it; it doesn't interact with any suspension. No steering, nothing. Therefore I cannot see a rule that prohibits it."
A fit person can exert 4kg of force through exhaling through a 1 foot long conduit,volarchico wrote:I think I have to agree with Brian on this one...that's quite the circuitous route for signal air to take from the DRS to the source (nose inlet?). Ever try to blow through a 3000 mm long straw?
JohnsonsEvilTwin wrote:http://www.autosport.com/news/report.php/id/98035
Bloody brilliant I tell you! =D>
Maybe just maybe, Mercedes have a podium chance for the first few fly away races.
These are 2 Absolutely different concept. Both Ross & Charlie confirmed it. Charlie talked about the "REAR WING" concept operated with DRS & not FW. So yes these are two completely different concepts.Fredy4 wrote:Are you sure?
Mestrades wrote:I think that to copy this system in such little time will be very difficult for the other teams. I have a question, the hole of the RBR nose is not the same? Charlie Waithing has said that there are "SOME TEAMS" ...
Merc have come under fire a few times the last couple of years, and sometimes probably deservedly so. But I'm getting a real kick of it that others are finally copying Mercedes.JohnsonsEvilTwin wrote:http://www.autosport.com/news/report.php/id/98035
Can't we just let the FW f-duct die now?Fredy4 wrote:Are you sure?
That's what I thought it was doing initially, it works with DRS in stalling the rear wing better. Don't know if that is really what is going on or not.shelly wrote:Now the autosport article adds some confusion by saying merc system acts on the rear wing.
wow, you are in full-on denial.shelly wrote:Now the autosport article adds some confusion by saying merc system acts on the rear wing.
In a way the other teams' solutions will not be as integrated as the Merc. But equally - on the flipside - that is winter development time that Merc spent on their device; which others spent on "conventional" development. They will have a bit of an advantage throughout the season - but it will somewhat diminish thorugh the season IMO. Merc will still end up above the break even line though.Fredy4 wrote:Good news is that. Even if teams copy it, thats time other teams have to take out of theirdevelopment, meaning theoretically mercedes still have the advantage all through the season.
They are in the endplates. It's the area that is exposed when the top flap rotates.Holm86 wrote:So suspension is only to deflect bumps on the road. But the DRS actuator is not only for activating the DRS flap?? You can also use as a duct opener or a can crusher?? Thats just FIA retarded logic!!
But how does this system work? You cant have a slit in the main plane of the rear wing.
So the duct or ducts must be on the topside of the main plane??
So when they open they bleed the high preassure air on top of the wing into the wing and into the endplates then out somewhere????
