avantman wrote:
21 May 2025, 10:17
Russell didn't have such big tow on his 1st lap in Q3 if he had any. He gained less than a tenth relative to his previous run (2nd run on soft in Q2), and literally nothing compared with his first run in Q2. His run out of the last corner on his 2nd Q3 run on medium was very poor because he had to give a way for cars on fast laps, which is why he lost time on the straight, otherwise he would've been P2 at least. He mentioned that himself after Quali.
And itt's quite strange that you give so much meaning to lap times set in Q1, measuring gaps between Mercedes and Mclaren pace. Not only we all know Max is probably the only driver who is always on it from lap 1 in Q1 coming closer to the limit quicker than other drivers, whereas other take few laps to find their references, Max had a tow worth 0.15s on his first lap in Q1.
well.
Russell had a tow on both the first run of Q2 and the first run of Q3. So your observations fit (that he gained just under a tenth from tow vs 2nd run of Q2, and gained nothing compared to 1st run of Q2 which also had the tow). My point is even with his tow, both laps on new soft were 2-3 tenths off the pace of Mclaren/RBR on new soft.
Q2 first run (3 tenths off P1) with tow from Verstappen:
Q3 first run (2.6 tenths off P1) with tow from Alonso:
The tow was worth 0.085s,almost a full tenth, when you compare to 2nd run of Q2 without tow.
So tow corrected, the gaps on new soft were closer to 3-4 tenths off the pace.
The only reason that Russell got much closer on the final runs of Q3 is because the medium tire (C5) was a much better qualifying tire than the soft (C6). That medium tire also put Aston comfortably into Q3 when they were closer to P10 on merit. Mercedes went with that strategy because they knew they were far off and had to gamble. Red Bull and Mclaren had the margin to use the worse tire. Ant was out in Q2 on a circuit that he already knew...The race further supports that Mercedes had big problems here.
I don't know what caused Mercedes to be slow here, but they were clearly slow in every situation. Russell was searching for tows on all of his runs (the others were confident enough to run on their own), in Q3 he burned his only set of mediums for the race in a desperate attempt to qualify better and rely on track position. Ant was out in Q2. Draw your own conclusions.
SB15
SB15
Lasssept
68
- Lewis Hamilton’s former Perfomance Engineer, Mike Sansoni, bids farewell to Mercedes.
OverheatedTurbo
OverheatedTurbo
Read that they reverted to the old rear susp. spec for Monaco. Not good. Any pictures of the car to confirm this?
Lasssept
68
OverheatedTurbo wrote:
23 May 2025, 13:03
Lasssept wrote:
22 May 2025, 20:18
OverheatedTurbo
OverheatedTurbo
Lasssept wrote:
23 May 2025, 13:25
23 May 2025, 13:03
#-o oh nooo
SB15
SB15
23 May 2025, 13:43
Lasssept wrote:
23 May 2025, 13:25
23 May 2025, 13:03
#-o oh nooo
Oh yes. Because there was nothing wrong with the suspension. Softer setups, more give for the suspension, means better tyre degradation.
OverheatedTurbo
OverheatedTurbo
The team just took out the Barcelona spec wing……my god..
OverheatedTurbo
OverheatedTurbo
23 May 2025, 14:14
I underestimated the impact of TD018. The team has changed the front wing to the flexi wing variant. We might be going to purgatory it seems. It was fun being podium contenders though.
23 May 2025, 14:20
23 May 2025, 14:14
Yes they've realised how much the new front wing was costing them perhaps
OverheatedTurbo
OverheatedTurbo
23 May 2025, 14:25
23 May 2025, 14:20
23 May 2025, 14:14
Seems to me that the 2025 concept was designed overly reliant on the flexi-wings. I think they should throw 2025 to the bin and just focus 2026 if they’re doing this to be fair..
Lasssept
68
This is the end
Beautiful friend
This is the end..
Mansell89
Mansell89
Only caveat is that this is FP1 Monaco- I doubt it’s a desperation move.
Lets see FP2
SB15
SB15
Lasssept wrote:
23 May 2025, 14:33
This is the end
Beautiful friend
This is the end..
Didn't make that much of a difference. The car, as I predicted, doesn't have that front-end bite and this is an issue that plagued most Mercedes cars in the turbo hybrid era.
I knew this weekend in particular was going to be a struggle at the start of the season.
OverheatedTurbo
OverheatedTurbo
Mansell89 wrote:
23 May 2025, 14:40
Lets see FP2
Perhaps. If they are confident, they’ll bolt back the new fw in fp2
