Mercedes AMG F1 W03
Gridlock
30
Re: Mercedes AMG F1 W03
When I read Charlie's comments, all I can hear is Bernie's voice saying "wouldn't it be nice if he (MSC) got another win?"
#58
clipsy1H
-16
just 10h and 34 min :D and we see duct!!! today i bet 100$ on Schumacher at top3 and Rosberg top 8
( hope they use duct in practice to night )
dren
227
Devilsadvocate wrote:i think all teams and just playing mind games..firstly RB says that he doesn't know why MGPW03 cant be a winner and then concludes that there would be in for an unusual win under different circumstances.
http://www.planetf1.com/driver/18227/75 ... ual-to-win
PlanetF1 is a sh!tbox of a site ususally. But, as RB has stated in his interviews, the car is good, it will be up front, but it may take a while through the season before it is capable of winning. Brawn states the team is good and is set-up to succeed in the future.
Probably should put this in the team thread.
Honda!
dren
227
raymondu999 wrote:The first step to understanding what the paddock word is - and to get consistently good news - is to stop reading Planet F1.
haha you beat me to it...
on to the Mercedes f-me-duct...
is it all one system operated by the DRS or do you suppose it could be more than that?
Honda!
Med4224
So gills are back?
we're screwed...
Few are those who see with their own eyes and feel with their own hearts.
Albert Einstein
Gills can indirectly make downforce you know.
The F-duct is very interesting..
We know the rear wings can't have any slots. So what then? It is all more complicated that Charlie did not mention the front wing... but still.
3.10.2 Other than the bodywork defined in Article 3.10.9, any bodywork behind a point lying 50mm
forward of the rear wheel centre line which is more than 730mm above the reference plane,
and less than 355mm from the car centre line, must lie in an area when viewed from the side
of the car that is situated between the rear wheel centre line and a point 350mm behind it.
With the exception of minimal parts solely associated with adjustment of the section in
accordance with Article 3.18 :
‐ When viewed from the side of the car, no longitudinal vertical cross section may have
more than two sections in this area, each of which must be closed.
‐ No part of these longitudinal cross sections in contact with the external air stream may
have a local concave radius of curvature smaller than 100mm.
thomin
I'm pretty sure the gills weren't the reason why last years car sucked and they won't make or break the W03 either.
Mr.S
Mr.S
Med4224 wrote:Image
So gills are back?
we're screwed...
This is bad. This is going to screw some what the pat of flow,and look at the position of the gills. Very key zone. Merc is going to loose a few tenths because of this.
Ferraripilot
21
Is it me or does the above pic look like the exhaust exit is more inboard than before.
And I don't really see the gills as a bad thing. The US Airforce did experiments in the mid-1960s with slots milled in the wings of experimental aircraft. When air was blown through the slots drag decreased without losing lift. Also, the direction of the gills are in parallel with the exhaust yet the coke bottle section directs the gill exit air towards the exhaust meaning that air will be subject to the energy supplied by the exhaust 'charging' that air towards the rear further.
The_Truth
The_Truth
Forget about the gills, this year is all about tyres and exhausts.
yener
Ferraripilot wrote:Is it me or does the above pic look like the exhaust exit is more inboard than before.
You cant compare that because the body is not fitted on the floor at that picture.
"Life is about passions - Thank you for sharing mine" MSC
Rikhart
Rikhart
Crucial_Xtreme wrote:Merc duct opening??
image via F1Talks.pl
That is without a doubt the shadow of the top plane winglet, that is opened.
veYda25
Med4224 wrote:Image
So gills are back?
we're screwed...
This whole area looks like it does not belong there... lets see if they just experiment with something in free practise, or if they use it in qualifying and race. i remember an interview with ross brawn after the first barcelona test where he said how happy they were with the car performing just as they expected without any cooling issues.
i'm sure it does not mean a bad thing at all.
Coefficient
Coefficient
[img]http://www.f1talks.pl/wp-content/upload ... 97.jpg[img]
I disagree. Look at the end of the short chord flap. The plate that covers the opening in the end plate is attached to the end of the flap. It's perfectly visible.
Reason: Removed image quoted from post above
bonjon1979
bonjon1979
30
You're just plain wrong - look at the shape of the small plate on the end of the DRS flap that when closed will rotate down to cover that hole. It's clear as day that it's not a shadow.
