Renault R30
quidam
quidam
Re: Renault R30
madly wrote:Blackout what's wrong with the drawing above?
exhaust is hidden in the sidepod, you can't see like in the drawing.
Re: Renault R30
That's just a vectorised real image from the early R30 (photographed in the studio). The current R30 has a complete different black bodywork, hidden exhaust pipes and a nozzle in the floor... that drawing is simplistic and wrong.
autogyro
autogyro
Re: Renault R30
Nice.
I am beginning to think that the other teams should start taking more notice of the renault.
That back end looks very tight and only lacks the pull rod suspension and better ride height control.
Re: Renault R30
In fact, its rear end is much much tighter than that... The R30 diffuser has two steep and high air channels (red rectangles) surrounding the gearbox (red triangle). They take much place in the black rear bodywork (yellow)...
the black rear bodywork:
quidam
quidam
Re: Renault R30
Re: Renault R30
I told you guys it wasn't a cooling duct! That bigass cone thing is coming from the floor.
sadzik
sadzik
Re: Renault R30
another update to the front wing
(C) by http://www.wri2.net
Re: Renault R30
More and more Sauberesque
manchild
manchild
Re: Renault R30
Exhaust is modified too
Re: Renault R30
It's the same.
manchild
manchild
Re: Renault R30
It is moved further backward and more flattened, reaching all the way to that aero part that guides the air and fumes.
Re: Renault R30
:wink:
and it's dirty (=already used)
madly
madly
Re: Renault R30
There is no hole on top of back engine cover. Upper DDD deck winglet is more shaped (on previous version it was flat). So for sure there are some evaluations of EBD to explor more DF from it.
mith
Re: Renault R30
Sadzik, could you post that photo once again?
After FP1 it looks, they're fast but lacking straight line speed in second sector.
madly
madly
Re: Renault R30
Is it something new?
