Are there any pics/video regarding wing flex?
How does it compare to other top teams?
Max looked quite comfortable in the car all weekend unlike to the 3rd day of test, which means that they must have found something in the simulator to make the v2 floor work.
I think 2024 had good tire wear if the tires were in the right window. This car seems to be in the right window.venkyhere wrote: ↑17 Mar 2025, 08:05Thanks guys, so looks like the v2 floor with the new front wing is indeed working well. Comparing to the Q3 time for RB20, RB21 is ~0.5s faster. That bodes well. And it seems to me that with Max at the helm, RB21 can 'match-up' to MCL39 when the tyres are relatively fresh. The 'tell' that this is indeed the case was the behaviour of the car in sector1 and T9-T10 in Australia. Car does seem to have good traction out of slow corners and is able to handle sudden opposite load shifts laterally, without understeering. Tyre wear is the biggest elephant in the room now (as it was in 2024 as well), because I think the problem with rotation in slow turns is solved (from eyeballing, I admit). Kerb riding is the other issue , which remains to be seen on tracks with big kerbs.
Lawson has the old parts (maybe gave him more confidence)
Interesting image, looks like a bare tub (presumably the spare) as no substantial suspension hardware etc is installed.
Different material for less or more heat transfer? GP told Max to try a different "test cycle on braking" so they are looking at either getting rears upto temperature or not overheat.
