Ferrari F14T
diemaster
diemaster
Re: Ferrari F14T
Re: Ferrari F14T
2014 Australian Grand Prix - Friday, 14.03.2014
ironrose
ironrose
Re: Ferrari F14T
it appears Kimi had to make many steering corrections compared to Fernando... would the steering configurations be different on both the cars???
Mandrake
Mandrake
Re: Ferrari F14T
Very good video showing how drivers are not using the whole rev band. If you look closely you'll see that the shift lights are fully on long before the car reaches maximum allowed revs. When Kimi accelerates out of T1 is it very well visible that he keeps on revving quite a lot after all lights are on.
rssh
Re: Ferrari F14T
stefan_ wrote:2014 Australian Grand Prix - Friday, 14.03.2014
Why is there chrome ring were the nose and the wings are attached?
Is it height adjustable just as the suspension are contracted or elongated sometimes (the chrome ring changes there too) to ride height adjustment.
Re: Ferrari F14T
http://i.imgur.com/IDq5ncM.jpg
nice image. first one I've seen of the back brakes. Interesting how the calliper is on it's back below the disk. While on the front they are vertical (standing up if you will) behind the disk.
Don't remember if the rear callipers where in the same position last year.
basti313
basti313
Re: Ferrari F14T
??? The blue helmet is Fernando, he is doing much more corrections than Kimi. But this is related to the usual problem: They can not get heat into their tires. While Merc and RB are doing fast laps after the outlap, the Ferraris have cold tires even after an additional warm-up lap. At least it seems they solved that problem for Kimis car in FP2.
Don`t russel the hamster!
Re: Ferrari F14T
I wouldn't read to much into that. I bet that those lights aren't set to a static value. I bet they change based on the mapping they are running and are simply there to tell the driver when they want him to change. For all we know they could be shifting at 8k.
Re: Ferrari F14T
andto answer my own question this pic is from autralia 2013 Image
so it was the same last year. positioning of rear calliper hasn't changed.
Mandrake
Mandrake
Re: Ferrari F14T
I wasn't denying the fact that these are programmable. But I got the impression that Kimi wanted to rev it to the max as he used to do with the old V8, whereas the best compromise between speed and efficiency lies where the rev light indicate the limit.
CBeck113
CBeck113
51
Re: Ferrari F14T
From the images I've seen so far, Ferrari is the only top team not using the heat from the brakes to heat up the wheels. Mercedes, RB, McLaren, Williams, Sauber etc. (OK, not all top teams, but still) do so. I'll add the images later, but I find this a bit odd - will the tires hold longer without this system?
motobaleno
Re: Ferrari F14T
if true, this is interesting since I would say that it's not particularly difficult from the technical pont of view.
so, if they don't do it, it's because they explicitly don't want to...
basti313
basti313
Re: Ferrari F14T
Do they already have two solutions? Because in FP2 Kimi managed to have the tires warm after the outlap...
aleks_ader
90
Re: Ferrari F14T
On test they also evaluated that possibility.
From Jerez
https://pbs.twimg.com/media/BhU0AzwCcAEdUOv.jpg:large
Emerson.F
Emerson.F
Re: Ferrari F14T
Supporting: Ham/Alo/Kimi/Ros/Seb/Hulk/Ric/Mag
