Red Bull RB10 Renault
RZS10
359
Re: Red Bull RB10 Renault
So much for broken/distorted chassis:
http://www.motorsport-total.com/f1/news ... 51409.html
"Am alten Chassis wurde kein Schaden gefunden", erklärt Chefingenieur Paul Monaghan gegenüber 'Reuters'.
"We did not find any damages on the old chassis"
H2H
H2H
So that it everybody can easily see and find the relevant part I link directly to the Reuters UK article, which has the following answer by Paul Monaghan.
The 'old' chassis has not been found to be distorted," chief engineer Paul Monaghan said in response to a query.
"The investigation is ongoing as the extent of the checks is vast in order to be thorough. No one error can be considered an entire explanation and requires further work to that completed prior to and within the Spanish GP.
"Changes to some ancillary equipment and preparation procedures has resulted from the checks made thus far," Monaghan added.
"Once all the information is available, Red Bull will address the points found in order to implement a complete solution."
So far a clear no, without (obviously) ruling out future findings as lots of (other) checks have to be ticked off. This leads me to the question how AMUS, generally one of most reliable ones, came up with such an article? They clearly implied that Vettel said the bit about the chassis by the way the parts were set. We will see how things go on from there, but so far it doesn't reflect well on AMUS...
Trust is hard to gain and easy to lose, they should know it...
djos
116
Tbh I see it as partisan media playing cheer squad for their countryman - it's not the first time and won't be the last (I'm not singling out amus here, Aussie media is just as guilty).
"In downforce we trust"
basti313
basti313
H2H wrote:So that it everybody can easily see and find the relevant part I link directly to the Reuters UK article, which has the following answer by Paul Monaghan.
You should not miss the different meanings of "chassis" when you judge hard.
Paul Monaghan is possibly talking about the pure survival cell as the "chassis". Whereas the first measurements were possibly done on the whole "chassis" at the wheelhubs. This would give the answer why they could not find the problem before: At the track the aligning is not done under load, whereas in the factory they have tools to measure the whole car under load.
Maybe even the change of the gearbox helped the rear axle more than the change of the survival cell. This would be even a better reason for not matching rear axle settings as the survival cell ends in front of the engine.
Don`t russel the hamster!
AMuS
atlantis
atlantis
21
What's that?
The batteries?
The whole engine maybe? :O
F1NAC
172
Is that mgu-k at the bottom?
Yes it's the MGU-K placed low on the left side of the engine.
XRayF1
XRayF1
True as it may be, it would not explain RB's quality control and/or operations control at actual racing weekend.
While I may accept that a thorough investigation about a 'chassis distortion' may not have happened during the first few races, I would think that RB has to take measurements (at wheelbase, at the joints, etc.) each time the car is unloaded from the trailer.
I mean, a trailer and a plane is not a stable environment, a lot of vabriations for sure, and RB would have to check this again and again, if VET kept complaining about the behaviour of the car.
To me it sounds more as a convenient excuse for VET's reputation.
On the other hand, he may have to prove now that it was indeed the car and not him.
basti313
basti313
Here you can see which tools are used for wheel alignment at the track:
http://www.f1technical.net/forum/viewto ... 38#p455438
Redbull uses similar ones, but I can find no picture at the moment. These are just homemade guides which are fitted to the front or rear stands to adjust camber and track. There is no connection/alignment between these and especially no 4-wheel laser alignment. So you just can not measure a distortion in the chassis with these tools.
In the factory they have a laser alignment and this finds every distortion.
XRayF1 wrote: To me it sounds more as a convenient excuse for VET's reputation.
You can believe what you want to believe. Feel free.
djos
116
What rubbish, most of the teams have been using laser alignment at the track for years!
Bomber_Pilot
djos wrote:What rubbish, most of the teams have been using laser alignment at the track for years!
RedBull use a piece of string. I will try to find some pictures when I get to the computer.
Of course you can measure a misalignment between them, that's why they string the cars up for cross measurements.
Tim.Wright
330
All the laser alignment in the world will not detect a chassis defect because the ride height, camber, caster and toe adjustments will hide any problems exactly as they are designed to do.
The only thing that can detect SOME of the issues, is sonic wave devices. But even then it's still difficult.
