McLaren MP4-28 Mercedes
Huntresa
Huntresa
Re: McLaren MP4-28 Mercedes
Well one of the problems was the tires how they acted aerodynamically, they will now change back to 2012 way of working the air so that means Mclaren will get it abit easier.
JimClarkFan
JimClarkFan
27
I'm slightly confused as to why people are saying that Mclaren won't fair better on the 2012 tyres, given that several have said the issues are because of the disturbed air flow at the rear caused by this seasons tyres; given that Macca are working hard in the area around the rear tyre even going as far to cut holes in the floor; given that Macca are complaining about the ride; and given that the tyres this year are known to be completely different in size, shape, strength, texture and flexibility compared to last years tyres which fits nicely with the rest of the story.
Macca are also adamant that they have more total downforce this year but claim they cannot use it because of the bouncing around. Many have pointed to pullrod yet Ferrari don't have problems. Ride is known to be the problem, therefore tyres might be were the blame lies - it took 1 and half seasons to sort out their tyre degradation problems who is to say that it won't take Mclaren just as long to sort out ride issue.
I have also heard that Macca designed this years car from data generated on 2012 tyres. If true it isn't hard to envisage serious pitfalls for a team who goes super aggressive in their design approach, only to then come a cropper when it turned out that all the simulations where based on data which turned out not only to be obsolete, but potentially very misleading.
Then there is the ancient characteristic of a great many of Mclarens cars, which is that they run their cars extremely stiff compared to others. Tyres are the only thing that have changed this year, I suspect their general philosophy of running a stiff car has not.
Therefore I don't see how anyone can rule out a drastic increase in performance. It is at the very least possible that the car fairs better on the older Pirelli tyres, maybe even very well provided they haven't fooked their own heads up with all the crap data they have been generating chasing their tail.
I for one would love that yet I don't hold my breath.
The geometry of the Mclaren pull-rod is hugely different from the Ferrari.
This is reminiscent of when Ferrari copied the rear pull rod of Redbull but made the end links too low. The result, massive turbulence of blown exhaust gasses and sever under-steer. They finally corrected it in Monaco of that year (2011? or 2012?)
raymondu999
n smikle wrote:The geometry of the Mclaren pull-rod is hugely different from the Ferrari.
I don't remember any such issues - but the 2011 Ferrari still had push-rod rears and fronts.
失败者找理由,成功者找方法
Racer X
Wednesday im just waiting to see the first views of the car comming together.... Hopefully tomorrow new pics of the MP4-28.
RedBull Racing Checo//PEREZ
mclaren_mircea
mclaren_mircea
I only hope that Mclaren doesn't go for the pull-rod in the design of the next year machine. It may have lot's of benefits but I don't think that Whitmarsh will risk again with the pull-rod after this year's results. Mclaren surely will revert to push-rod next year, and will not took this risk again.
Germany 2013 - Thursday (04.07.2013)
aral
aral
26
I see they have solved the problem of exploding tyres! Artillery wheels.
Holm86
255
stefan_ wrote:Germany 2013 - Thursday (04.07.2013)
Is it just me or does the nose look low here???
I thought so too but i can't find a good comparsion Pic.
Edit:
This is Monaco:
Looks the same.
Holm86
255
Guess its the same. Angle just fooled me.
khaliweed
khaliweed
Its the same. Just not yet mounted.
Different rear wing flap. They now run the fatter flap solution compared to the thinner solution, this gives a more neutral effect with DRS activated.
Germany 2013 - Friday (05.07.2013)
