Airshifter wrote: ↑23 Feb 2020, 16:54
Since the use is not when turning the steering wheel, and not intended to steer the car, the biggest change it makes when implemented on the straights is to change the aero wash over the wheels.
If "steering" means the control of the direction rather than just a change of it, they could argue that their system is there to improve stability on the straight, even though it's pretty obvious that there are actually other reasons.
In any case, pure genius by Mercedes for developing it. I'm sure they have covered all bases to be able to switch quickly to not using it just in case it is banned.
Imo, the MB DAS is hardly a ground-breaking innovation. Surely MB are not the first to think of adjusting toe on the go, as static settings require a compromise between straight and cornering. An OP in the W11 tread has also provided images/link to a road car that had this capabiliy over 10 years ago. It's just a question of whether MB managed to implement it without breaking the law by the letter of it. (Btw, the use of longitudinal movement of the steering wheel as a mean of control in a racing car was already present in Japanese cartoons originally dating back to the 1970ies, though in that case it is used to change wings AoA
It's gonna be entertaining. It may not be very easy to keep it if the "unintended consequences" are far more relevant than the declared primary objective, that is, "steering".
