Ferrari F14T
Redragon
19
Re: Ferrari F14T
miguelalvesreis wrote:
Redragon wrote:I think Pilatus is right, as it rotates on the direction of the tyre rotation.
:wtf: the wheelhub can't rotate. It would be deemed as movable aero decide.
If you check the wheelhub it is not all a hole, they did kind of pipe pointing outwards and it only covers half of the whole, so the hole exit rotates with the wheel, it points up when that half area is on top and it points down when that half area is pointing down.
Hope I have explained myself clear
Redragon
19
Re: Ferrari F14T
PhillipM and Owen.C93 you might be right actually after a second look. Still the wheelhub I think makes that illusion I was describing, interfiring with the vortex
eslam1986
eslam1986
Re: Ferrari F14T
jagunx51
185
Re: Ferrari F14T
PhillipM wrote:Looks more like the vortex from the edge of the front wing to me.
edit: it is, you can see it in front of the tyre.
yes..... it would be black dust if comes from brake pad wear
jz11
jz11
19
Re: Ferrari F14T
if you follow your own logic through (the nut in the bottom pic being fed air from the same source as the top one - brake intake duct), then where is the light blue line of the brake duct flow in the upper picture?
timbo
timbo
113
Re: Ferrari F14T
Oh dear...
Well, for once, what would be the force acting on the stream of air to change its direction on the "before" variant?
Kiril Varbanov
147
Re: Ferrari F14T
Autosprint suggests that F14T may feature new nose at Spain - http://autosprint.corrieredellosport.it ... ppi/14870/
Re: Ferrari F14T
timbo wrote:
Oh dear...
I think he's completely missed the point of the blown duct to be honest #-o
eslam, it doesn't do anything like your picture, think about where the air was going before through the brake ducts compared to now.
Re: Ferrari F14T
My video of how it could be the nose Ferrari developed on the basis of the old and that seen on the Mercedes W05
charlex
-4
Re: R: Ferrari F14T
zioture wrote:My video of how it could be the nose Ferrari developed on the basis of the old and that seen on the Mercedes W05
no please no I dont want to see that lawn mower! Ferrari and Mercedes have different aerodynamic demands so I dont think your concept-car will be similar to the real one
Re: Ferrari F14T
Seeing how Ferrari's nose relies on air around the nose cone a narrower nose might be a possibility.
timbo
timbo
113
Re: Ferrari F14T
Thunders wrote:My guess would be a shorter Nose similar to that Merc did. Not narrower or higher, just shorter.
It's pretty much as short as it can physically be already IMO
Re: Ferrari F14T
timbo wrote: It's pretty much as short as it can physically be already IMO
They have about the same length to shorten than Merc did. A little less, but still a good chunk to cut away.
TeMpL
TeMpL
Re: Ferrari F14T
Redragon
19
Re: Ferrari F14T
Spanish press reporting that the increase on speed on the straights is because of a new rear wing introduced on china.
And for spain the nose will be shorter and higher and some changes on the engine to improve the electric side.
Here is the link, sorry I can't get the google translate link as I am spanish, but if you open with google chrome will do automatically
http://www.marca.com/2014/04/23/motor/f ... 41748.html
