Mercedes AMG F1 W03
hardingfv32
hardingfv32
Re: Mercedes AMG F1 W03
Raptor22 wrote:I'm pretty convinced the flow goes rear to front.
As mentioned before, the holes in the end plate are in a position of very high pressure (where you would normally see vortices streaming off the wing in humid conditions).
The scale is hard to read in this image, but it is 0.125 PSI just in front of the flap or secondary element. Is that enough pressure to get the flow to the FW slots? What is the pressure reading going to look like if the flap is open?
Also note how the pressure is NOT 'piling up' out at the end plates as is the common belief by many on this forum.
As always, PM with Email for a PDF
Brian
Uploaded with ImageShack.us[/quote]
hardingfv32
hardingfv32
Raptor22 wrote:drag reduction looses downforce which creates a loss of tyre heat. This needs to be compensated for with a mechanical set up that works the tyre harder.They can't really do this because DRS is used over a very short section of a circuit so their set up must still work over the whole lap. But if they loose heat while DRS is enabled then they are at a disadvantage exiting slow corners. We don't really see this. What we see is a general inability to keep the tyres within their operating window which tells me they have erred to far on the side of caution.
This is a weak theory:
1) We have no idea of the nature of the tire problem.
2) The FWFD is not producing very much downforce/drag reduction. Nor do we know if changes of downforce on the straights have much effect on tire temps. This has never been discussed in regard to the DSR on or off this forum before since it was introduced.
Brian
NewtonMeter
NewtonMeter
shelly wrote:
raymondu999 wrote:EBD worth 2 seconds? :wtf:
Indeed. Tombazis said the ballpark for performance gain with ebd in 2011 was 2sec in a recent interview
Good gief! I stand corrected. Develop away fellas, my first consignement of midnight oil is already on the way...
Nothing is foolproof to a sufficiently talented fool...
madly
madly
I wonder, why you guys still think about W03 as speed killer, ultra qualifying performer?
Look at the facts.
In Sepang qualification first 5 places were in 0.2s and it was shared between 4 different teams including MGP (MCL, MGP, RBR, Lotus)!
If you see speed trap values, and best speed at particular sectors there is no supremacy of W03 at all. Yes W03 is quick, but it's far from F-duct time where MCL had few more km/h speed advantage.
Yes W-duct is innovative but some teams obtain similar results without this system.
Maelstrom
Maelstrom
madly wrote:I wonder, why you guys still think about W03 as speed killer, ultra qualifying performer?
Look at the facts.
While its true that Mclaren are clearly faster and the rest of the pack were separated by a few tenths at most MGP has performed well at both races in qualifying. If true to form there is no reason for them to not repeat the performance.
Unless ofcourse the car is set up more for race pace and not qualifying.
RobertPthe3rd wrote:Ebds are still important. Anyway you can get more rear df, means you can have more overall df. And the rb ebd was worth more than .8 I would say closer to 2 seconds so 25% is still .5 huge in f1 that's 10th to 1st at some races
THe effect of the EBD is GREATLY reduced this year. Have you seen how a Renault with no EBD is much faster than the ReBull in Qualifying? The same for the MErcs.
hardingfv32 wrote: 2) The FWFD is not producing very much downforce/drag reduction.
Great how you come to those conclusions, but how do you know that?
Drag System Reduction, really? #-o
hardingfv32
hardingfv32
wesley123 wrote: 'This has never been discussed in regard to the DSR on or off this forum before since it was introduced.'
The context of the statement was that rear tire cooling had never been discussed in relation to DSR usage. The is first time I have heard of such an issue. Do you have any other info?
Brian
hardingfv32
hardingfv32
I am working on some numbers but I could us something data on the FW.
Lycoming suggested using the FW test weight, but how does it translate to wing load across the surface of the wing? I need surface loads to make a rough assignment of downforce for the wing elements.
Assuming a simple single element FW, does the aero downforce require to bend the wing match the weight placed in the test location, that would also bend the wing an equal amount? Seems like the aero downforce number could be much larger.
Anyone of a logical way of calculating this relationship?
Brian
xpensive
xpensive
214
More like; "Did I dress like that when I was Nico's age...?"
Ooops...off topic, I think MS is quite happy with the W03?
MercAMGF1Fans
MercAMGF1Fans
Hi guys.. my best pics of the car last time out in Sepang.. the cars looked awesome in that much rain..
Dragonfly
Dragonfly
Do you have a photo with the car not so zoomed? It's interesting to see the water sprays around it.
Spa 2012
Brian
I am not trying any discussion here, I am just correcting you. It isn't DSR it is DRS
MercAMGF1Fans
MercAMGF1Fans
Dragonfly wrote:Do you have a photo with the car not so zoomed? It's interesting to see the water sprays around it.
got loads mate.. i went crazy hahaha
http://photobucket.com/sepang3
http://img.photobucket.com/albums/v613/ ... SC0326.jpg
http://img.photobucket.com/albums/v613/ ... SC0377.jpg
Dragonfly
Dragonfly
MercAMGF1Fans wrote: got loads mate.. i went crazy hahaha
Thanks a lot =D>
Spa 2012
