Ferrari F14T
Rikhart
Rikhart
Re: Ferrari F14T
Rear suspension geometry change? Hard to tell because of different bodywork, but I think so.
Source: http://www.f1analisitecnica.com/2014/06 ... sulla.html
Re: Ferrari F14T
New Bodywork TECHNICAL ANALYSIS
Read all here https://translate.google.it/translate?h ... alifica%2F
flyboy2160
flyboy2160
84
Re: Ferrari F14T
Car threads are about actual car parts, not about hypothetical updates and lap times.
Re: Ferrari F14T
Rikhart wrote:Rear suspension geometry change? Hard to tell because of different bodywork, but I think so.
http://2.bp.blogspot.com/-jT_GqmEaKno/U ... ecarlo.jpg
That and wets are taller.
George-Jung
George-Jung
Re: Ferrari F14T
It are inters.. :wink:
SpainFAN
SpainFAN
Re: Ferrari F14T
I see that they are trying really hard to generate a positive pressure at the end of the "coke bottle" but I fell like even doing so, they still would need to increase the rake to further increase the upwash and generate DF.
This configuration does seem to improve fast cornering control, moving the CP (Central Pressure) backwards on the body and better controlling centrifugal force on the rear end. Also the shape as vied from above seem to show a more airfoil top camber shape than before, where a higher AoA (cornering) would have laminar separation bubble detachment sooner, causing that wiggle we saw in Chine on both cars.
flyboy2160
flyboy2160
84
Re: Ferrari F14T
Wind tunnel general comments in the Team thread. Car parts only here.
Re: Ferrari F14T
.poz wrote:
n smikle wrote: I think the ferrari has severely compromised intake runners with that big old intercooler between the banks. Not to mention the air has to take a u-turn then a 90 degree turn in another axis. They must have alot of guide vanes inside that thing!
It's a turbo engine. The key is to minimize air intake length, not to minimize air friction.
At the end of the day minimizing air friction and intake length is what you want, but if you have compromised runners, all of that will go down the drain. I have seen guys change their turbo intake manifolds and reap tens of horsepower. So you have to Keep that in mind when it's clear Ferrari have the weakest engine combined with a midfield chassis even when they created this car all under one roof.
The Moderator
-1
Re: Ferrari F14T
Engine cover tested in Canada, hope to work in Austria :wink:
Cuky
65
Re: Ferrari F14T
Rear end tested in Canada got it's visa for Austria too
Also back on the car is single wing support pylon
aleks_ader
90
Re: Ferrari F14T
I m wondering if perspective plays trick with me. Is there " under rear "swan" support on the base arc around exhaust really another ("new") end tip winglet? Much more progressive curved upwards. Little differs from originally introduced version witch also include 2 flap monkey seat? That could be replacement for "strait" arc version for "mclarenish" monkey seat or is that edge still the same and perspective plays tricks with me.
Page in topic
http://www.f1technical.net/forum/viewto ... start=1935
http://img4.auto-motor-und-sport.de/Fer ... 779857.jpg
If is that true, could that mean onother more agresive monkey seat?
f300v10
f300v10
185
Re: Ferrari F14T
Is this rear brake duct aero new? It looks like more elements than I remember:
Gilles 27
Re: Ferrari F14T
Finally they risk more with this aggressive looking new Aero Pack, was about time.The single wing support pylon, looks more sophisticated and , like the others before made, looks now really up to date.
Looks Allison first bigger intervention on this car, looks good. Hope that Ferrari can make some steps forward now.
George-Jung
George-Jung
Re: Ferrari F14T
Why do they put this yellow thing in front of the exhaust exit?
Re: Ferrari F14T
Austria 2014 - Thursday (19.06.2014)
