Mercedes AMG F1 W03
dren
228
Re: Mercedes AMG F1 W03
Look at what happened to Raikkonen...it was just what happened to Nico at the first race. If you fall out of the narrow tire performance window, you're screwed hard. It will be a crap shoot with guessing the weather conditions if only a few degrees make all of the difference.
The W03 is a great car as are several on the grid.
The DRS is pedal activated on the W03 right? I couldn't tell when Nico was using it during his pole lap. It would be nice to see when he uses it.
The braking does look very stable. This car also looked planted in the corners. The team has really made some good changes on the overall balance compared to the last two cars.
Honda!
WhiteBlue
92
hardingfv32 wrote:...
The speed differential between Rosberg and Button was much bigger in Q3 than it was in the race.
The Mercedes setup was biased for downforce instead for straight line speed as witnessed by the speed trap numbers.
We know that simultaneously reducing drag and downforce at the front and the rear has also an effect on ride height, rake and understeer. All three points are improved. The rake differential between DRS on/off is minimized, the understeering tendency is reduced and the ride height can be minimised as well. The DDRS can be used deeper into the corner and earlier out of the corner. Through the corner the car has better balance than a car that only uses DRS on the rear wing.
The combination of the three points in my opinion clearly shows that the Mercedes DDRS was used to pile on more downforce than it would have carried with a single DRS system. In China Mercedes went to quite extremes of downforce and used it to generate pace through the corners and not through the straights as they used to do last year. It was only possible to do this because they could run in clean air. If they had lost the start Nico would have been in trouble with his straight line speed.
Reason: Removed quote of a post that has been deleted.
Fizz.Schumi
Fizz.Schumi
Mate I think like last year the DRS button is on the back of the wheel
Crucial_Xtreme
Crucial_Xtreme
404
It's on the steering wheel. Sky Sports had a segment where they compared Nico's best Q3 lap to Michael's and you could see Nico press the DRS button on the steering wheel way before Michael did. In fact, Michael didn't press the DRS button at all coming off of turn 16 on his Quali lap. Pretty sure the DRS button is on the left side of the steering wheel
Crucial_Xtreme
Crucial_Xtreme
404
It's on the steering wheel. Top left button.
http://www.youtube.com/watch?v=Zjg0kFBSU6w
dren
228
Must be on the back like stated above. I think KERS is the red button on the top left.
Honda!
dren
228
[img]http://img84.imageshack.us/img84/2562/mercdrs.jpg[img]
Thought that was KERS? He releases it half way down the straights.
Reason: Removed image quoted from post above
Honda!
Crucial_Xtreme
Crucial_Xtreme
404
I originally thought that too, but watch him coming out of the last turn. There is no KERS harvest left, yet when he pushes(and holds) that button the DRS is activated.
Owen.C93
Owen.C93
177
I'm pretty sure that's KERS. He presses it whenever he uses KERS and there's at least 2 examples of when he doesn't press it and the DRS still activates.
Crucial_Xtreme
Crucial_Xtreme
404
Owen.C93 wrote: I'm pretty sure that's KERS. He presses it whenever he uses KERS and there's at least 2 examples of when he doesn't press it and the DRS still activates.
Maybe so, but at the end of the lap for example he's pressing that button, there is no KERS to use and the DRS opens. But you & Dren are right, that's the KERS button. My apologies. Just saw that piece on Sky and they had me thinking it was the DRS actuator. Weird he was pressing that button with no available KERS.
I notice he never mentions the DRS actuator.
http://www.youtube.com/watch?v=LIM3UdX4zT0
Fizz.Schumi
Fizz.Schumi
This is last years video where nico explains the wheel :
http://www.youtube.com/watch?v=aphrHIAI1JY
at 2:23 he says that the rear wing button is at the back because they ran out of space on the front of the wheel ;) My observation was correct (rarity) :D
Although yeah I noticed whilst watching schumi's video from this year that he didn't mention it.
Owen.C93
Owen.C93
177
It's probably just in case there's any left.
hardingfv32
hardingfv32
1) The speed difference between Mercedes and others was large. This does indicate a plus for the DDRS.
2) Downforce bias, I do not see how this favors a DDRS position. Mercedes Qual trap speeds were not unusually slow. I do not see anything indicating a downforce bias.
3) All the facts about a well functioning DDRS are true, but they provide no indication the Mercedes system is providing any of these advantages.
So only one of your three points supports your position that the DDRS is of value.
Yes, Mercedes had a different setup from last year. What were the race trap speeds like, was Mercedes one of the slowest?
Again, I do not see the importance of running in clean air. What is the definition for a clean air safe distance? No one in the trains that develop in the field during the race seem to worried by dirty air.
I also do not buy the logic of Mercedes betting on a pole after years of poor performance and a weak start to this year.
Brian
WhiteBlue
92
Brian,
Merc have the system on the W03 and they would not have gone to a massive design effort if it were as useless as you say. Equally they would not have been attacked as vehemently if the system was useless.
I see little point in further discussion. You might have noticed Anderson's opinion that more teams will be doing DDRS pretty soon. The first versions are expected from Barcelona. We can easily wait and see whose opinion is correct. At least I don't need an endless opinion debate. So let us have different opinions until the paddock comes to a clear verdict over the system.
hardingfv32
hardingfv32
WhiteBlue wrote:Brian,
We have know about this system since Oct 2011, plenty of time for the competition to modify their chassis before the start of the season. Yet not one competitor has shown a system to this point.
Brian
