Williams FW36 Mercedes
RZS10
359
Re: Williams FW36 Mercedes
According to Pat Symmonds Williams had a broken fuel pump.
It has to be so annoying that even those "small" issues can take several hours to identify and quite some time fix due to the complexity of the new power trains. They lost one day of testing because of that.
MadMatt
MadMatt
125
RZS10 wrote:According to Pat Symmonds Williams had a broken fuel pump.
In what world a failed fuel pump is difficult to diagnose?
RZS10
359
That's what pat said:
Bei Williams gibt es wohl größere Probleme, wie Technikchef Pat Symonds gegenüber auto motor und sport erklärt: "Wir haben jetzt endlich den Fehler gefunden. Die Benzinpumpe ist defekt. Bei diesen komplizierten Systemen ist die Diagnose nicht so einfach. Wir hoffen, die Reparatur schnell hinzubekommen und vor dem Ende der Sitzung um 17.30 Uhr noch einmal auf die Strecke zu gehen."
~There were bigger problems at Williams, as Pat Symmonds explained to amus: "We finally found the error/issue. The fuel pump was broken. Diagnostics in those complex systems are not that easy. We hope we can repair it quickly and get out onto the track before the session ends at 5:30pm"
Callum
There might be quite a difference between 'failed' and 'not working how it should'. The pump may well have been producing fuel flow just in the wrong manner!
Winter Testing 2014 - Session 2, Day 1 - Bahrain (19.02.2014)
zoro_f1
-2
click for HR...
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Winter Testing 2014 - Session 2, Day 2 - Bahrain (20.02.2014)
Winter Testing 2014 - Session 2, Day 3 - Bahrain (21.02.2014)
roadie
39
Here's a quick video of the FW36 being driven in relative anger. Lots of gear changes!
http://www1.skysports.com/watch/video/s ... o-williams
Winter Testing 2014 - Session 2, Day 4 - Bahrain (22.02.2014)
Winter Testing 2014 - Session 3, Day 1 - Bahrain (27.02.2014)
jagunx51
185
double cooling slot? ......the upper one is very close to the fuel hole
scarbs
scarbs
393
Williams ran new horizontal sidepod vanes this morning
