ClarkBT11 wrote:alvinkhorfire wrote:ClarkBT11 wrote:
Hamilton's starts have improved a great deal compared to the start of the season, he tries to hold back if he's starting in second place in the warm up lap trying to leave Rosberg sitting at the start line longer to allow more heat into the clutch of Romberg's.
Correct me, if I am wrong. I thought that during the warm-up lap, each car needs to be within 2 car lengths from the car in front. It seems that Hamilton is sometimes further behind. This is an inappropriate tactic used by Hamilton, right?
It's ten car lengths but it looks more than that near the grid. If Hamilton does it I don't see why Nico chooses not to use the same tactic.
There are obvious reasons, but we will not figure out which one is true, so discussing them is useless. And the discussion would spoil the thread already before the race.
Steven wrote:It's certainly going to be considerably cooler than on Friday and Saturday.
The 35°C from Quali will be 26°C and clouds instead, so expect an even larger drop in track temperature than those 9 degrees.
This should play to the advantage of those starting on the super softs, including Verstappen and the Force Indias.
Well, I did not believe in the usual talk about tires lasting only one lap. We had this so many times and it was never true, they always managed to run the option tire for 10 to 15 laps when 2-3 laps were "announced" after Q.
Of course 10 laps in Spa is a lot, but anyways Ves will be able to run 7-9 laps on the SS, maybe even more when it is cold, which leads to an easy SS-S-S or SS-S-M.
His stop will leave him right in front of Ham and then trigger a lot of S starter stops for track position. And this track position is the key: He will always be able to stop before the others and will be on the right tire to finish the race in the end. Others will need to go on the SS or M at the end, which leaves them either in a difficult position in dirty air or simply too slow to overtake.
I think, except for the Mercs, SS-S-S is the tactics to go for.
