But you can see some small silver part on MS exhaust just inch above exhaust.Gerhardsa wrote:Dont know how you can see from those pics if there are any difference mate?
Back heat protection etc looks the same as previous races. I for one cannot even see the exhaust outlet when zooming in because the pixels get all messed up
I don't necessarily believe this is true.Ferraripilot wrote: Correct, Scarbs did indeed mention this is a benefit quite some time ago. Lower ride height can only be a benefit if W03 also has a passive system which runs just off the front nose cone hole. If the super-DRS system is only activated while DRS is activated then they obviously cannot set the ride height lower as the only time it can be used during a race is when passing, so it's business as usual as far as ride height is concerned unless we find out they have a passive system running as well.
Might be sensors, or vents. Well, maybe not vents, because it'll be an odd place and totally disrupt the airflow goingt to the floor. I dont think there are updates scheduled before Spain.aduka11 wrote:But you can see some small silver part on MS exhaust just inch above exhaust.Gerhardsa wrote:Dont know how you can see from those pics if there are any difference mate?
I dont remember seing it before.
+1sponbon wrote:I don't necessarily believe this is true.Ferraripilot wrote: Correct, Scarbs did indeed mention this is a benefit quite some time ago. Lower ride height can only be a benefit if W03 also has a passive system which runs just off the front nose cone hole. If the super-DRS system is only activated while DRS is activated then they obviously cannot set the ride height lower as the only time it can be used during a race is when passing, so it's business as usual as far as ride height is concerned unless we find out they have a passive system running as well.
If you read Alan Permane's comments above, he suggests that the ride height can be lower in the race than in qualyfing.
From my reading of his comments, it appears that the slower speed due to fuel load etc. means less load on the wing and thus increased ride height. Accordingly, qualyfing is the key determinant of ride height, as this is when the cars run lowest, not the race.
Therefore, due to the Double DRS, Mercedes can run a lower ride height for both race and qualy.
Ps. First post. Been a lurker for a while. Love the forum.
As I understand it, from the start of qualy(following through to the race) the ride hight is lower than what it would have been on the Merc if they didnt have the DDRS, because of the "stall" effect the DDRS creates on the F&RW.Raptor22 wrote:lower ride during qualifying when the fuel load is lowest..?
explain how this can be when they are not allowed to change the ride height from the start of qualifying?
Usponbon wrote:I don't necessarily believe this is true.Ferraripilot wrote: Correct, Scarbs did indeed mention this is a benefit quite some time ago. Lower ride height can only be a benefit if W03 also has a passive system which runs just off the front nose cone hole. If the super-DRS system is only activated while DRS is activated then they obviously cannot set the ride height lower as the only time it can be used during a race is when passing, so it's business as usual as far as ride height is concerned unless we find out they have a passive system running as well.
Parc Ferme starts when the cars roll out in Q1. (if a car rolls out in Q1 with 3 minutes to spare, it is out of parc ferme, until that moment)Byron R wrote:Might this be why we always see teams adjusting the ride height for qualy3, I would assume parc ferme rules do not apply yet.
