Ferrari F14T
Re: Ferrari F14T
New Cover Engine used during qualifying
Pilatus
22
Re: Ferrari F14T
zioture wrote:New Cover Engine used during qualifying
https://fbcdn-sphotos-c-a.akamaihd.net/ ... 1418_n.jpg
Air temperature forecast for today is around 30 degrees.
So - bigger cooling openings are logical.
Pilatus
22
Re: Ferrari F14T
Owen.C93 wrote:Why do they still run such massive brake ducts if they A: Don't run blown wheel nuts and B: Still fill the ducts with material to block them off.
F1NAC wrote:Is there a possibility that they run smaller holes at wheel nuts?
Front wheel are blown on F14.
But instead of blowing air through wheel axle and nut, there is a annular opening on brake basket/drum:
Same solution that Red Bull is using for last few seasons:
Probably they (Ferrari) tried two, or even more, different solutions, and current solution came on top.
Re: Ferrari F14T
Hungary 2014 - Thursday (24.07.2014)
Flanker27
Flanker27
-2
Re: Ferrari F14T
Why they don't try a less draggy (and less ugly) nose?
Mercedes raised his nose on 2nd or 3rd gp, if i am not wrong...
TechF1
Re: Ferrari F14T
Flanker27 wrote:Why they don't try a less draggy (and less ugly) nose?
Useless cause next year the Ferrari nose will be legal all the others not... it's not a joke. 8)
TechF1
Re: Ferrari F14T
Redbullish vortex generator on Ferrari's diffuser. =D>
Re: Ferrari F14T
Why would they?
And Mercedes brought the tip of the nose rearward, not higher.
Re: Ferrari F14T
Why would they?
It got a little bit higher too.
I think Ferrari are using a different philosophy, trying to get the air around the outside to the inside underneath the chassis. And a lower nose also means a lower CoG.
Re: Ferrari F14T
A new intake air brake
bhall II
bhall II
477
Re: Ferrari F14T
I think you're seeing the same basic brake layout photographed from different angles and at different stages of setup.
The discs are different, though. :D
Re: Ferrari F14T
Looks like the Hockenheim Verion was RP'ed and in Hungary it's finally made out of Carbon.
Re: Ferrari F14T
bhall II wrote:I think you're seeing the same basic brake layout photographed from different angles and at different stages of setup.
The interior of the intake is different looks this pic normal ( CANADA ) and first evolution in German GP
Pierce89
Re: Ferrari F14T
Thunders wrote:Looks like the Hockenheim Verion was RP'ed and in Hungary it's finally made out of Carbon.
That's what I'm seeing as well.
Re: Ferrari F14T
Formula1.com
