Under full trottle, the MGUK can harvest up to 100 kw, but not instantly, just down the straight.eyelid wrote: ↑27 Aug 2025, 14:50Let's make it more clear shall we?
If driver lifts of the throttle, is it allowed the ICE to charge the battery then like in Toyota Prius when car is just coasting? Can the ICE still charge the battery even when demanding 100% load full throttle? Like in same time?
This is the real thrill of the rules if allowed, like replacing the hybrid turbo with more simple approach ICE straightly charging the battery, and not via complex and costly turbocharger unit.
Part- and off-trottle, harvesting is limited by the reduced fuel flow limit there.
I suggest you download the technical regulations. Section 5.2 is of interest to you.
Edit: sorry, complet wrong.
