Mercedes AMG F1 W05
mbchc
mbchc
Re: Mercedes AMG F1 W05
ismail1991 wrote:I think nose is different than the one used in previous races
http://i.imgur.com/rhZdVgq.jpg
Compared to this, we can see they make the gap bigger between the pylons. Likewise, they did it in W03 and W02
It's seems rounder at the edge, and the nose tip was a little bit taller again? :roll:
Mercedes AMG Petronas
AMG|||
SectorOne
I think they have bent the front wing pylons outwards a bit. Get more air under the nose.
Nose is also way more concave as someone mentioned, small gif i made, not perfect but will do.
emmepi27
emmepi27
141
So, it's not the best pic, but we can confirm that they have "new" nose, more rounded in the lower part (note the shadow on the silver)
Holm86
249
SectorOne wrote:I think they have bent the front wing pylons outwards a bit. Get more air under the nose.
http://gifmaker.me/files/download/home/ ... zszVvX.gif
Definitely a whole new nose cover. There is also much more curvature from the bulkhead to the nosetip. It can also be seen on the camera mounts where the camera mount "stalks" is shorter.
Great gif SectorOne
SectorOne
thanks, watching the stream right now and got a nice front view of the "hole" and it looks like the same width.
So only a more rounded nose and some modification on the sides of it.
"It can also be seen on the camera mounts where the camera mount "stalks" is shorter."
Yep good point.
George-Jung
George-Jung
Camera mounts are also different.. due the nose being 'higher'..
Nicola11
Nicola11
Good shot at the new designed front of the W05 Hybrid :)
SectorOne
Now the question is what does the new nose do? From a straight to concave surface and a bigger cutout on the sides.
RicerDude
27
I say it could perhaps be a Low downforce, low drag nose like the RB9 had last year in Spa/Monza. The rounded edges should reduce drag and lower the pressure build up on top of the nose maybe slightly reducing downforce produced by the front end.
ncassi22
ncassi22
31
It's more convex at the top than concave at the bottom. My guess is it reduces aero pressure at the nose tip.
*edit* aka what ricerdude just said
gray41
So it might only be seen here and Monza?
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
New nose other comparision
So that is three different noses and we are only half way through the season.
Belgium 2014 - Friday (22.08.2014)
