McLaren MCL35
jh199
32
Re: McLaren MCL35
OzanA wrote:
16 Feb 2020, 16:23
Mansell89 wrote:
16 Feb 2020, 15:43
OzanA wrote:
16 Feb 2020, 11:58
Bargeboard looks so complex in daylight
Do you think it’s a lot different to the launch renders and the launch car at MTC?
A LOT different than renders
https://i.imgur.com/2xK3BuR.png
https://imgur.com/eLC13Ca.png
I wouldn't say "A LOT" different. There are a few new vertical vanes toward the front of the barge boards but as far as I can see that's it. It's nice that they're adding parts to the car this rapidly
SmallSoldier
SmallSoldier
486
Re: McLaren MCL35
This picture seems to show the POU that Mclaren will start the season with:
f1rules
f1rules
623
Re: McLaren MCL35
the car really looks amazing on track, looks like they are measuring flow to the front brakeducts, or just protecting, with that metal thing, at the back though, they are meassuring the flow at the floor, please let the numbers be good
https://pbs.twimg.com/media/EQ6gzhJXsAE ... name=large
_cerber1
275
Re: McLaren MCL35
ALO_Power wrote:
16 Feb 2020, 18:23
Hmm u sure that the bargeboards are very different with the renders?
Ivan said that he spent a lot of effort on their design. So what I'm waiting for here is a big change as the tests progress.
Lucky
Lucky
157
Re: McLaren MCL35
Re: McLaren MCL35
godlameroso wrote:
15 Feb 2020, 16:02
Tim.Wright wrote:
15 Feb 2020, 08:19
My guess is that it's not for kinematics but to give an acceptable force base to react the cornering forces. The lower arm is attached at wheel centre height more or less. If you attach the upper arm inside the wheel your force base length will only be 100mm or so.
Btw raising the upper arm won't necessarily increase the roll-centre, nor will a higher roll centre necessarily induce understeer. Both of these effects are a function of the complete suspension kinematics, not just the upper arm.
If you raise both arms roll center does go up?
There was something I read that goes: Formula 1 roll centres do not mean much.
Re: McLaren MCL35
the EDGE wrote:
16 Feb 2020, 11:44
A nice summary by Matt Somersfield,
Hi Matt! Is that you?
Haven't seen you here in some time! :wink:
the EDGE
the EDGE
68
Re: McLaren MCL35
PlatinumZealot wrote:
16 Feb 2020, 21:25
the EDGE wrote:
16 Feb 2020, 11:44
Yes it’s been a while, but No, it’s not him! Just thought others might like to watch to while away the hours till Wednesday
Ground Effect
Ground Effect
Re: McLaren MCL35
f1rules wrote:
16 Feb 2020, 21:07
yeah sorry, that was not well formulated, livery looks amazing
Looks like you got your POU... :wink:
Flying JPS Lotus
37
Re: McLaren MCL35
The airbox and sidepod shape remind me of the Toro Rosso's from 15-16.
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
lio007
324
Re: McLaren MCL35
f1rules wrote:
16 Feb 2020, 19:36
AFAIK teams are not allowed to use aero rakes during filming days.
Re: McLaren MCL35
Posts about the Livery and testing programme have been moved to the Team Thread. Please keep it about the hardware of the Car in this Thread.
Motörhead
Motörhead
Re: McLaren MCL35
lio007 wrote:
17 Feb 2020, 07:09
f1rules wrote:
16 Feb 2020, 19:36
These are not Aero Rakes as they are incorporated into the structure of the car and could be run all season long in this configuration
f1rules
f1rules
623
Re: McLaren MCL35
maybe thats why they are so small and well hidden :-) i didnt think you could either, but these spikes are there to measure for sure, weve seen them before on other cars also, and mclaren used last year during testing, maybe if they use all the way through tesing its legal i dont know
lio007 wrote:
17 Feb 2020, 07:09
f1rules wrote:
16 Feb 2020, 19:36
f1rules
f1rules
623
Re: McLaren MCL35
i know some sources say, and i hope its that, because makes absolutely sense to exploit that path when you have a weak frontend, but im still not 100% convinced, since others use a lot more space for their solutions, im not sure if mclaren coud fit it in there, they ran similar solution last year, and yes there seem to be a change in material going from carbon to metal, we will se when there is better pictures, ill se if i can find the picture from last year. It looks like they moved it further out
Ground Effect wrote:
16 Feb 2020, 22:08
f1rules wrote:
16 Feb 2020, 21:07
